Battery Maintainer 500mA - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 06-22-2006, 09:46 PM Thread Starter
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Question Battery Maintainer 500mA
Have ordered a sealed battery, but am still using the wet cell and need
to now if when using very small amperage to maintain or (charge) do the
battery caps have to be removed?
The Battery Maintainer I have came from JC Whitney and is only 500mA,
the amperage going in is so little that even after leaving it on for 8 hours
I don't see any bubbles coming up, so in my mind it might be OK to leave
the battery caps on?
The Battery Maintainer is working because I can hear the faint sound it
makes when putting it close to my ear.
norsseman is offline
post #2 of 2 (permalink) Old 06-22-2006, 10:36 PM
Loran in Npvl IL's Avatar
The wet cells have a vent so you shouldn't have to remove the caps when you charge withe a battery maintainer. You still should remove the caps weekly to make sure the water level is correct.
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
