Upgrade headlight bulb - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 04-18-2011, 02:34 PM Thread Starter
spiral_72's Avatar
I've been searching for an answer for this on these forums and Google... Maybe this will benefit someone else too:
I like the stock headlight, but not the bulb. The light is a little weak and always has been. It's more of an old-school warm low-penetrating glow.
As I have recently found out, the charging system is a bit fragile, so I'd prefer to keep the power draw on the bulb as close to stock as possible. All other lighting components are stock.
Does anyone have any recommendations? It looks like the OEM bulb is a 9003 running at 55 and 60 watts for low and high beam at a 4000K color (correct me if I'm wrong). I guess what I'm looking for is "I tried XYZ bulb and was really disappointed" or "I use ABC bulb and it pulls the same as the OEM part but much better visibility"
PIAA has an H4 Xtreme White Plus it states is a 55/60W at 4000K with the light output of a 100/110W for $75 for a two pack.... a bit pricey I think... but maybe it's really that much better? I don't see a one bulb pack.
Also a H4 Intense White 55/60W = 125/135W at 4100K a little cheaper for $65 per two pack.
Power consumption is a dumb way to rate bulbs honestly, but who am I to change that?
spiral_72 is offline
post #2 of 22 (permalink) Old 04-18-2011, 02:58 PM Thread Starter
spiral_72's Avatar
Some of the above info come from right here under the "Headlight" section:
https://www.vn750.com/forum/showthread.php?t=1129
post #3 of 22 (permalink) Old 04-18-2011, 03:03 PM Thread Starter
spiral_72's Avatar
Nevermind. I can't figure out how to delete this whole post. I called PIAA and just gonna go buy one. It's $50 and they assured me it pulls the same power (current) as the OEM bulb. The nice lady said the double light output comes from the gas they use.
H4 Xtreme White Plus, P#70456 $50 for one bulb.
I got to thinking there really no way for anyone to tell me how great a particular bulb is, so I'll just give it a shot. Also, I'm gonna see about putting an ammeter on both bulbs and take a picture at night with both. Maybe that'll help someone.
post #4 of 22 (permalink) Old 04-18-2011, 03:56 PM Thread Starter
spiral_72's Avatar
This looks interesting as is the price. Too bad I can't find any real information on it!
http://www.harborfreight.com/automot...ulb-98247.html
post #5 of 22 (permalink) Old 04-18-2011, 06:48 PM
jcwhitney has h4 bulbs too. You can check them out too.
post #6 of 22 (permalink) Old 04-18-2011, 06:59 PM
scuba's Avatar
I ordered mine from harbor freight and love it. you can tell a big difference between stock and this bulb.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #7 of 22 (permalink) Old 04-18-2011, 07:34 PM
The xtreme white is the way to go. A cheaper alternative is the Silver star, but not heard how well it works in the Vulcan.
There is a post somewhere about H.I.D lighting you should check out ...
post #8 of 22 (permalink) Old 04-18-2011, 08:38 PM
johnm's Avatar
I bought a china-mart Silverstar 9003/HB2 ST a few months back and it is much brighter than the stock headlamp. That said, there could still be the tendancy for one to easily overdrive the light. I feel that I could use more light...maybe a light bar addition and/or HID conversion would be better. But no other complaints with the Silverstar so far.
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #9 of 22 (permalink) Old 04-18-2011, 09:07 PM
Patriot Guard Rider
The DEUCE's Avatar
I went with the Sylvania SilverStar Ultra.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #10 of 22 (permalink) Old 04-18-2011, 09:33 PM
peerless's Avatar
Do you have a part number for the one you ordered, scuba? Is it the one linked above? I have a harbor freight near me and I need a bulb. Thanks
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
