Where's the short? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-10-2011, 07:32 AM Thread Starter
Where's the short?
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #2 of 6 (permalink) Old 04-10-2011, 09:23 AM
Plan your trip with only left turns and you'll do fine.....
Not the horn, maybe the connector under the tank from the ign. switch or the bullet connector in the same location. I don't think it's a 'short' but a loose connection.
dariv is offline
post #3 of 6 (permalink) Old 04-10-2011, 10:45 AM
Check the ignition switch connector. It is in the light bucket or some where's around the turning neck area. I am not sure, i never had that problem.
post #4 of 6 (permalink) Old 04-10-2011, 10:57 AM
The connectors are under the tank..... you can get to them from the left side cover, (the one between the fork and tank). The only things that should be in your light bucket are the connectors for the 'dash', tach, speedo, head light, turn sig, and an accessory plug........
dariv is offline
post #5 of 6 (permalink) Old 04-10-2011, 11:06 AM
Chucklehead
dragon159's Avatar
2X checking the wires from the ignition. I had one rubbed through there and took out fuses on a regular basis until I fixed it. Sounds more like a broken wire, just a little harder to find.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #6 of 6 (permalink) Old 04-11-2011, 08:42 AM Thread Starter
deleted
