Starting issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-10-2011, 05:42 AM Thread Starter
Starting issue
I have the MF battery and it really works better however once in a while I turn the key on and it acts like a dead battery. Engine will not turn over.
Happened just the other day after the wife and I loaded it up for a three day ride. Went to leave the house and nothing! No start. No crank over! Unpacked all the luggage from the VN and loaded it onto the Suzuki 1200 Bandit.
When we got home, I tried to start the VN and it fired right up! The same thing happened the last time this happened.
How about a ground or a connector? Anybody have this problem? How about the ign. switch? When it does not start, the dash lights will come on so I don't know about the switch.
honest Al is offline
post #2 of 11 (permalink) Old 04-10-2011, 05:48 AM
sounds like a bad ignition switch... next time try wiggeling the switch and/or cycling the key off an on..
post #3 of 11 (permalink) Old 04-10-2011, 09:21 AM
johnm's Avatar
^^^x2 on the ignition switch. Mine did the same thing when I first got it. Seems pretty common with these bikes. I ended up pulling the switch out, cleaned it, stretched the spring inside, resoldered a loose/broken wire...no trouble since. Cheap fix compared to buying a new one.
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #4 of 11 (permalink) Old 04-10-2011, 08:55 PM Thread Starter
I agree that it could be the switch......but the dash lights come on.
I had a problem before with the switch.....I turned it on and nothing happened at all.......no lights......no nothing. I wiggled the key in the switch and presto it was fine.
This time the dash lights come on and the engine will barely turn over like the battery is dead. Walk away......come back and it spins the engine like nothing is wrong!!!!
How do I fix something like this??
post #5 of 11 (permalink) Old 04-10-2011, 09:07 PM
Patriot Guard Rider
The DEUCE's Avatar
I have to turn my key all the way right to the "P" position and then back to the "ON" position for my bike to start.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #6 of 11 (permalink) Old 04-11-2011, 02:25 AM
Journey's Avatar
try checking the clutch safety switch.
My Enuf.
1995 Vulcan 750
New wires and plugs
Removed and cleaned carbs
re routed air line to right ear
re built transmission
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #7 of 11 (permalink) Old 04-11-2011, 04:04 AM
If it turns over slowly and acts like a dead battery with a fully charged battery, then I would look at the main grounds. there is one on the left side of the frame, and one on the rights side next to the starter solenoid. one or both are either loose or corroded. try cleaning and tighten them.
Journey... if its the clutch safety switch, it wouldn't turn over at all.
post #8 of 11 (permalink) Old 04-11-2011, 08:07 AM
Heading to the DARKSIDE!
BRET H's Avatar
My starting issue ended up being the positive battery cable wire where it attaches to the front of the starter was very loose and oily. I cleaned it off ...then put some blue Loc-tite on the nut....then put dielectric grease over the whole connection. Starts very easy now!
BRET H is offline
post #9 of 11 (permalink) Old 04-12-2011, 04:28 AM
glad to hear it was an easy fix
post #10 of 11 (permalink) Old 04-18-2011, 02:09 AM Thread Starter
After it quit while running (I had to wiggle the switch) I finally bit the bullet and pulled the switch......cleaned it......stretched springs...etc.
Life is good again..........for now!!
