Left turn signal issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-07-2011, 10:16 PM Thread Starter
1986vn750's Avatar
I was just riding home from Chik fil a with my buds, about 9:45 pm. sitting at a light with my left turn signal on. I noticed after about 15 seconds, it started blinking really fast. looked back, rear wasnt working. So i thought i blew a bulb. (this is on my 2001 btw) i make the left, drive about 3 miles, get on an on ramp for a Highway, signal left to murge and it blinked normally, both bulbs working. what caused this? any one else ever have this issue?
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #2 of 6 (permalink) Old 04-07-2011, 10:22 PM
cm4cm5's Avatar
yea i had that..took the signals apart and cleaned the connection points. no problems since.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #3 of 6 (permalink) Old 04-07-2011, 10:31 PM
Patriot Guard Rider
The DEUCE's Avatar
Yeah, I had to adjust the socket and have had no problems since.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 6 (permalink) Old 04-07-2011, 10:46 PM
clock152's Avatar
just incase.. I would check the conections on your flasher too.. and maybe upgrade it to an electronic one instead of Thermal.
clock152 is offline
post #5 of 6 (permalink) Old 04-08-2011, 08:59 AM Thread Starter
1986vn750's Avatar
Since its the rear bulb that quit, just check the socket? and make sure the contact are clean and no rust.? thanks guys.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #6 of 6 (permalink) Old 04-08-2011, 09:06 AM
flitecontrol's Avatar
Dielectric grease will minimize corrosion once you get the contacts clean.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
