Bad Miss (Think due to battery help) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-07-2011, 09:17 PM Thread Starter
hillbilly's Avatar
ok i havent startd my bike in about a month been real busy, so me and the boy went out to put the battery in(the battery came out last year) well i told him to put it in and he accidently put it in backwards and it sparkd when he tried to put the cables on so any ways i took the battery out and put it in right and it was dead went to start it had to jump it took the jumpers off the bike got a horable miss turned the jumper up and it straightend out a lil but i mean the jumer is on 150volts so its putting out but is my stator bad or is the battery just that weak?
If It's Got Wheels I Can Drive It
If It's Got Hair I Can Ride It
K and N Pods
12 inch Aps
Handle Grips
Dual Break Lines
House Of Colors Candy Apple Red
Lowered
Road Pegs
Jetted
Coasters
Custom Exhaust
Red Plug Wires
Neons
Custom Switch Panels
Harley Turn Signals(Coming UPS)
Red Hoses
Removed Tach
Removed Speedometer
hillbilly is offline
post #2 of 5 (permalink) Old 04-07-2011, 10:09 PM
peerless's Avatar
Have you checked the battery voltage at rest, with the key on (bike not running), and at idle? Those readings would give you a decent starting point.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
post #3 of 5 (permalink) Old 04-07-2011, 10:39 PM Thread Starter
hillbilly's Avatar
no i didnt have any thing to do it with
K and N Pods
12 inch Aps
Handle Grips
Dual Break Lines
Lowered
Road Pegs
Jetted
Coasters
Custom Exhaust
Red Plug Wires
Neons
Red Hoses
Removed Tach
Removed Speedometer
post #4 of 5 (permalink) Old 04-07-2011, 11:00 PM
I recall reading in the service manual that connecting the battery backwards can fry some of the electronic ignition components instantly, including the r/r, the stator and the IC Ignitor (reference page 300 of the Clymer manual). I don`t know if that will cause the horrible miss you describe or not. Or if it would just not let the engine start at all.
In any event, do as peerless suggests, and check battery voltage as a starting point for diagnosis.
post #5 of 5 (permalink) Old 04-07-2011, 11:52 PM
clock152's Avatar
it will for sure blow some fuses.. don't ask how I know!...check the fuses.. charge the battery.. and when you do jump it make sure its from just a battery.. not a charger or car jumping device.. and not from a running car.....is your battery a wet cell or AGM?
clock152 is offline
