starter issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 04-06-2011, 11:05 AM Thread Starter
starter issue
Brand new battery, holds voltage, drops to 6 volts when starting. If you hold in the starter button it acts like the battery is totaly dead. Anybody help with this one?? Please
bergey is offline
post #2 of 17 (permalink) Old 04-06-2011, 11:24 AM
JM2001's Avatar
My first guess would be a shorted out starter solenoid or a problem with the wiring to the solenoid.
Jim
JM2001 is offline
post #3 of 17 (permalink) Old 04-06-2011, 12:20 PM Thread Starter
Can you tell me where to look for the solenoid?
bergey is offline
post #4 of 17 (permalink) Old 04-06-2011, 12:33 PM
pull out the starter, ground to case and put positive to terminal see if it spins, also spin pinion by hand should spin smooth and freely, you have the starter relay and starter lockout switch they are on the side of the battery case
qweesy is offline
post #5 of 17 (permalink) Old 04-06-2011, 12:36 PM
Welcome to the group.
Stop over to the newbie checkin and introduce yourself and your bike.
If you fill out your profile and signature on the User CP it will remind us where you are on every post , and whatever you want to say about your bike, ie model year, mileage, mods, etc.
Does battery voltage rise back to near 13 V when you release the start button?
post #6 of 17 (permalink) Old 04-06-2011, 01:55 PM
before you go to all that trouble make sure your battery is good,if the voltage id dropping that much it could very well have an internal connection on the battery that is almost completely open .A battery with this problem will show good voltage ,but when under load can't provide the current needed.Try a set of good jumper cables to the battery in a vehicle that you know can provide enough current to turn the engine over.if this doesn't help look for high resistance connection, i.e. corroded battery connections bad cables or starter solenoid.The big cables are what you need to check first as this sounds like a problem in the power side of the harness and not control .Then check the starter,and don't forget to drain the oil if you end up having to pull the starter.also be sure to check the connections on the big cable grounds.
But I think it is most likely the batteryJMHP
post #7 of 17 (permalink) Old 04-06-2011, 02:02 PM
true but the starter is pretty easy to get to on these bikes but yes check batt first, try jumping from your car or truck battery
qweesy is offline
post #8 of 17 (permalink) Old 04-06-2011, 02:11 PM Thread Starter
New battery, second one in two years, cause I thought that was the problem, NOT. Had the starter out last year and had it checked out by a shop, nothing wrong with it. Battery does go back up to 13 volts after you let go of the starter button. I figure that it is a solenoid or a coil or something like that. Does this bike even have a starter coil??
bergey is offline
post #9 of 17 (permalink) Old 04-06-2011, 02:17 PM
check and dielectric grease all starter connections and make sure they are all tight, oh and open up your starter switch on the handle bar and clean the contacts, on an older triumph I had the contacts were burned and all black cleaned them right up with some brasso put switch back together and started right up.
qweesy is offline
post #10 of 17 (permalink) Old 04-06-2011, 02:56 PM
Starter relay/solenoid is found on the right side of the battery box.
Follow the short, heavy, white/red electrical cable from the positive battery terminal to the relay.
Here is an ebay link to some pictures of vn750 relays to see what this one looks like:
http://motors.shop.ebay.com/__?_from...lenoid&_sacat=
