Bike Wont Start In the Rain. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-05-2011, 02:33 PM Thread Starter
...Any easy fixes?
vulcanpower is offline
post #2 of 7 (permalink) Old 04-05-2011, 03:17 PM
JM2001's Avatar
I would start at the sparkplugs. Older plugs with condensation on them will not fire. You could remove them and dry them off if needed. You may have water getting into the sparkplug boots. You might have water in the airboxes and the foam is very wet, causing an over rich fuel condition. The next place to look is wet electrical connections. That could be in many places.
Jim
JM2001 is offline
post #3 of 7 (permalink) Old 04-05-2011, 04:41 PM
X2- check the condition and color of the plugs first.
Park in as dark a place as you can find, and look at the spark plug wires and all other wires with the engine running.
Watch for any sparking or current leakage from the wires.
Spraying a fine water mist from a spray bottle onto the wiring and boots may make sparking easier to see, IF it is occuring.
If the water causes the bike to run rougher or quit, that will help to isolate the exact trouble area.
If you do detect any electrical leakage, replace the wiring.
post #4 of 7 (permalink) Old 04-05-2011, 05:13 PM
Originally Posted by vulcanpower View Post
...Any easy fixes?
Wait for it to stop?
If the bike starts fine evey other time but won't start when it is wet..you have "leak" in your electrical system somewhere. The others suggested checking the spark plugs/wire , but it could be a starter wire, the kill switch, a "hot lead" wire grounding out,.etc.
Not to mention a wet air cleaner....but you did not really say exactly what it does here...like does the motor turn over with the starter or is the bike completely dead?
How hard did it rain?.. need specifics.
post #5 of 7 (permalink) Old 04-05-2011, 05:26 PM Thread Starter
It rained hard and still is raining. I had to leave the bike at work. The starter motor sounds like it almost turns over, then fizzles out. I can hear it for a few seconds if I hold the button and hear a clicking somewhere down near the engine.
post #6 of 7 (permalink) Old 04-05-2011, 05:34 PM
JM2001's Avatar
The main problem sounds like a very weak battery. The clicking sound you hear is probably the starter solenoid not getting enough juice.
Jim
JM2001 is offline
post #7 of 7 (permalink) Old 04-05-2011, 06:16 PM
scuba's Avatar
definately electrical. I would check all the wiring. Yes, could be a weak battery or maybe the connectors need to be cleaned.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
