hid conversion help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-03-2011, 09:05 PM Thread Starter
Concert connoisseur
wib714's Avatar
hid conversion help
I know a few of you guys have these but has anyone experienced the hid light going out while driving? I have to switch to the halogen bulb but when I switch right back its on again. ride for a while and it goes back out. anyone else have this problem?
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 6 (permalink) Old 04-03-2011, 09:08 PM Thread Starter
Concert connoisseur
wib714's Avatar
tonight was the first time I got to drive it at night, what a difference, almost takes a little gettin used to, but it takes a lot of gettin used to when it goes out, thank god the lowbeam still worked. and why is the halogen on the high beam setting, are yours like this too?
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #3 of 6 (permalink) Old 04-04-2011, 01:52 AM
This quote is from Ron/lance on the original *HID or lightbar* thread.
I have had the above kit for almost two years and I would never go back to Halogen. The reason I bought the kit is because it has two seperate elements instead of one, Halogen low HID High. I swapped the terminals @ the H/L plug so I have H.I.D. Low and Halogen High.
This system is great with our Reserve Lighting Unit and can still switch beams if one fails, other HID systems use a sliding projector for High and Low from the same bulb and if it fails your screwed.
Judging from Ron`s statement you can use the HID in either hi or lo beam by switching the terminals at the headlight plug.
post #4 of 6 (permalink) Old 04-04-2011, 06:10 AM Thread Starter
Concert connoisseur
wib714's Avatar
I'll have to switch it, but still not sure why it goes completely out
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #5 of 6 (permalink) Old 04-04-2011, 09:05 AM
Have you checked all the connections? It's possible one connection might not be good. There is also a possibility the transformer is over heating & shutting down, cool off & work again. I know with neon we use where I work their transformers have a built in saftey that causes them to shut of if something is out of wack. You might want to contact the manufcturer on this aswell.
post #6 of 6 (permalink) Old 04-04-2011, 12:48 PM
Never had a problem with mine....... I guess I would check all the connections first. I also have the HID on the low beam.... seems fine to me.
dariv is offline
