Push starting in 1st? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-03-2011, 08:58 PM Thread Starter
Recently had trouble getting my bike started. I might've flooded the carbs and after trying to start it a dozen times it didn't even turn over. After a lot of fussing I found that if I rolled it while it was in first gear and hit the ignition button it would start right up. Is this a dead battery? Can I recharge it, or should I buy a new one? If I have to buy a new one, can anyone send me links to an acceptable battery that I should purchase?
vulcanpower is offline
post #2 of 12 (permalink) Old 04-03-2011, 09:44 PM
If you are able to get the bike into a higher gear, push staring is easeir. But I understand that it is impossible to go into a higher gear. I have never tried it.
post #3 of 12 (permalink) Old 04-03-2011, 10:02 PM
Concert connoisseur
wib714's Avatar
it is difficult to get into 2nd, if you have a slight grade its a little easier as you have to get up a little speed to get it in 2nd.
if you buy a new batt get an agm maintenece free. bought mine at autozone but others will chime in soon with some links to ones they prefer!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 12 (permalink) Old 04-03-2011, 10:06 PM
Headbanger/Popes of Hell
ruger's Avatar
for a good/cheap MF battery for the VN750, try Big Crank batteries
www.bigcrank.com
ruger is online now
post #5 of 12 (permalink) Old 04-03-2011, 11:29 PM
Do you have a voltage meter to check the battery?
You can try recharging the battery for 4-5 hours at a rate no higher than 2 amps.
Push starting Kawis is difficult because the Positive Neutral Finder prevents shifting into 2nd gear until the bike is rolling and has built up a little speed.
Here`s the MF AGM Deka battery made by East Penn:
http://cgi.ebay.com/ebaymotors/Deka-...item3eee173adb
post #6 of 12 (permalink) Old 04-03-2011, 11:34 PM Thread Starter
You misunderstood ... I am fully able to push start the bike at a roll in first gear, however, it won't start at rest in neutral.
post #7 of 12 (permalink) Old 04-04-2011, 12:41 AM
Ceal's Avatar
Do you know if this was available in the 1985 VN700? If it was, I don't think mine works lol.
Ceal is offline
post #8 of 12 (permalink) Old 04-04-2011, 01:13 AM
As far as I know all model years had the PNF. It is comprised of 3 little ball bearing in recesses in a tranny gear that are thrown to the outer circumference by centrifugal force as spinning begins. Yours must be stuck in some way.
Vulcanpower, I guess it is more accurate to say Kaws are more difficult to push start than if you could do it in second or third gear. I have never push started a bike, but I have with many cars and trucks over the years. First gear almost always skidded the tires in my experience. The mechanical advantage of 2nd or 3rd gear was always easier and more successful for me. Just saying.
post #9 of 12 (permalink) Old 04-04-2011, 01:40 AM
flitecontrol's Avatar
Sounds like pushing the bike in gear reduced how much work the battery had to do and allowed it to crank. So I would think the battery may be weak. Charge it and see how many volts it has. If not 12.5 or better it's probably no good. Could also take it to a place like AutoZone, etc. and have it load tested.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #10 of 12 (permalink) Old 04-04-2011, 02:15 AM
Same with mine Ceal. I can roll it a few inches, and it will slide right into 2nd. I can even spin the rear wheel by hand and it will go in 2nd.
I will have to consult the manual and see where those balls are, and try to fix them.
RakerBill is offline
