Turn Signal Fast Blink - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 34 (permalink) Old 03-25-2011, 10:01 PM Thread Starter
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Turn Signal Fast Blink *UPDATE*
The other day I was out riding, and noticed that my right turn signal started blinking very fast. A few turns later...it went back to normal. Then later that day, it did it again.
What the heck is going on?
Indications that the bulb is going out on the front or rear turn signal?
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #2 of 34 (permalink) Old 03-25-2011, 10:05 PM
flitecontrol's Avatar
Do you know Morse code? See if it's trying to communicate with you.
Sorry, couldn't resist!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 34 (permalink) Old 03-25-2011, 10:08 PM
clock152's Avatar
if you have regular bulbs one may be going out.. or your flasher unit...yes I said unit... is going out.
clock152 is offline
post #4 of 34 (permalink) Old 03-25-2011, 10:10 PM
cglennon's Avatar
A fast blink indicates that a bulb has blown or there is a bad contact somewhere.
Chris Glennon - Portland, OR
cglennon is offline
post #5 of 34 (permalink) Old 03-25-2011, 10:47 PM Thread Starter
Big Dumb Viking
asbrand's Avatar
Guess I'll try replacing the bulbs.
Are there any LED conversions out there that'll work in our bikes?
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #6 of 34 (permalink) Old 03-25-2011, 11:04 PM
Into the Darkness
NetMatrix's Avatar
Before you replace the bulbs for the turn signals, cause I had that same problem. Well of course look at the bulb make sure if it is blown or not. Int he socket there may be some rust or something causing the connection to suck. Clean that out good and put some bulb grease in there. If the bulb is not blown that should keep it working for you.
English Version
ACCT to MCCT conversion video
https://www.vn750.com/forum/showthread.php?t=18235
ACCT to MCCT Conversion Thread created by wib714
https://www.vn750.com/forum/showthread.php?t=17917
Proximity Construction
NetMatrix is offline
post #7 of 34 (permalink) Old 03-25-2011, 11:14 PM
Might find something here:
http://www.customdynamics.com/motorcycle_lights.htm
post #8 of 34 (permalink) Old 03-26-2011, 01:36 AM Thread Starter
Big Dumb Viking
asbrand's Avatar
Thanks...I'll check those out.
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #9 of 34 (permalink) Old 03-26-2011, 11:33 AM
cglennon's Avatar
LED conversions require replacement of the stock thermal based flasher unit with a no-load electronic flasher, $12 or less at any auto parts store. The low current draw of the LEDs will fool the stock thermal flasher into thinking that a bulb is out triggering the fast blink rate. The no-load electronic versions blink at a constant rate regardless of load. That also means adding a blinker check to your pre-ride routine to verify that the LEDs are functioning properly.
Radiantz 1.85" dual-intensity LED clusters fit perfectly within the screw post of the turn signal housing. A little dab of silicone adhesive will hold them in place.
The stock bulb base, a piece of coat hanger and silicone adhesive can be used make the connection Plug-n-Play.
Three of the Radiantz 1.85" dual-intensity clusters will fit within the stock brake lens. Brighter than stock incandescent bulbs at a fraction of the power!
cglennon is offline
post #10 of 34 (permalink) Old 03-26-2011, 02:59 PM
There are modulating LED brake bulbs too: http://cgi.ebay.com/ebaymotors/HARLE...item53e6c3a632
"Black Beauty"
Old Blue
