Cheap after market turn signals? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 03-16-2011, 12:44 PM Thread Starter
99vulcan750's Avatar
My bike hasn't had rear signals for 2 seasons now. I had to remove them for saddlebags, and now I want a pair to mount on the sissy bar or on the license plate frame. Which signals can I get that are fairly cheap and won't blink faster than the factory ones. I looked at a few on eBay, but not sure they will work. I had bought a plate frame with lights, but they blink REALLY fast and are really small...
any links or suggestions would be great. $50 is about my budget with shipping...
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #2 of 11 (permalink) Old 03-16-2011, 12:57 PM
OldBikeNewRider's Avatar
Wow, if you got $50 bucks you should go LED. I did a search on EBAY and bought ones that looked just like stock for about 9 bucks each if I remember right.
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #3 of 11 (permalink) Old 03-16-2011, 01:23 PM
flitecontrol's Avatar
If you go with LEDs, you'll need an electronic flasher unit. If you mount to the license light housing, you can use any signal with a mounting bolt. There's a recent thread on this.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 11 (permalink) Old 03-16-2011, 04:07 PM
I am running a Honda Cb650 tail light, and signal system on my bike.. got it from eBay for 10 bucks
post #5 of 11 (permalink) Old 03-16-2011, 05:13 PM
SlimVulcanRider posted this on another thread. I'd highly recommend these as they will greatly reduce the pull on your electrical system and save it!
1986 VN 750
20,000 miles
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
post #6 of 11 (permalink) Old 03-16-2011, 05:51 PM
are you referring to the "Clear Alternatives"? if so... even though they are LED, they aren't a power saver per say, because they have built in resistors to mimic the loads of a regular incandescent light bulb power draws... If you are looking to save power, you need to go to a true LED light and switch out the thermal flasher for an electronic one. You can get an electronic flasher from any auto part store for under 15 bucks. I bet you could use this to fix your license plate mounted lights that are blinking too fast... but you need to swap out your front lights at the same time.
post #7 of 11 (permalink) Old 03-16-2011, 06:07 PM
Not exactly cheap, but I just ordered up some LED clusters and smoked lenses from Custom Dynamics..... you can check them out here.... http://www.customdynamics.com/kawasa...signal_led.htm
dariv is offline
post #8 of 11 (permalink) Old 03-16-2011, 06:29 PM
IBEW 915 Electrician
hctublerub's Avatar
Try here. $20 apiece for turn signals if they have'em. I started another thread showing how to convert rear signals to front signals because this website always seems short of front signals.
http://www.darkhorsemotorcycleparts.com/
'01 Vulcan 750
Irridium Plugs
hctublerub is offline
post #9 of 11 (permalink) Old 03-16-2011, 10:13 PM Thread Starter
my plate frame mount wasn't LED, but the signal interval was wacky. I didn't want to have to install an electronic flasher unit.
so as long as I stick with something like this: http://cgi.ebay.com/ebaymotors/4X-Un...Q5fAccessories
I won't need a flasher unit, right?
Looking at my bike, I am gonna have to replace a few other parts this spring... Probably have to go lower than $50, lol.
TOC springs
Home made sissy bar
post #10 of 11 (permalink) Old 03-17-2011, 12:10 AM
those will work for the rear, but not in the front, and I can't tell what bulb they use... if they blink fast, go to autozone and get EP28 Electronic flasher for 14.99... it is plug and play, meaning just unplug your old thermal flasher and put this one in.
