Had to jump bike...now won't start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-14-2006, 12:26 AM Thread Starter
I need carbs rebuilt...was trying to get bike started to get it to the shop and I ran the battery dead. Attached jumper cables from bike to my old Honda Civic. Everything was turned off when I attached the cables. Put key back to 'on' position and the run switch to 'run', but all I get now is a click from the solenoid.
Any ideas?
1986 VN750.
fortygeek is offline
post #2 of 3 (permalink) Old 06-14-2006, 03:15 AM
Ernie's Avatar
Send a message via MSN to Ernie
Have you got a good connection at the jumper cable clips? I have used car cables to jump start my bike & the large clips can sometimes be difficult to get to stay onto the battery terminals. Also, if the bike battery is really old it may have short-circuited internally which would prevent the bike's electrical system getting full current from the car battery. Another thing you could try is to bridge the contacts on the solenoid with a heavy screwdriver or wrench to see if the engine turns. If it does then the solenoid is at fault. Make sure the bike is out of gear if you do this or you may get an unpleasant surprise!
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #3 of 3 (permalink) Old 06-15-2006, 10:02 PM Thread Starter
Thanks
Jumped across the solenoid and the starter cranked over. Got a new solenoid on order from Ron Ayres.
