Coil Wiring and Relay mod - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #21 of 60 (permalink) Old 02-18-2013, 10:21 PM
why/how could this Mod be any different on a Euro Model ?
Different models have different wiring color scemes...THATS why....
Manhunter...I have a wiring diagram you may want. PM me your email, and I will send to you.
it is Vn700 1985 a1-it was made only for usa
Same as my bike...VN700 is better than 750 !
post #22 of 60 (permalink) Old 02-18-2013, 10:23 PM
but i hear click befor i turning ignicition key
Make sure you disconnect and clean all of the main ground wires. Especially the ones in starter circuit. (I think there are 3). Very important.
post #23 of 60 (permalink) Old 02-19-2013, 03:43 AM
if nothing helps, can i get source of power elsewhere, like from taillight power cable. cause this cable provide electric when i turn a key.
thx
manhunter05 is offline
post #24 of 60 (permalink) Old 02-19-2013, 11:45 AM
I think that will work.
post #25 of 60 (permalink) Old 02-19-2013, 12:27 PM
@niterider
I have test it now for 2 days, power cable from backlight,workig very good.
Do you think,that thin cable will be enough as power suply?
post #26 of 60 (permalink) Old 02-19-2013, 12:35 PM
Yes that is enough, it doesn't take much to opperate the relay.
post #27 of 60 (permalink) Old 04-01-2013, 11:12 PM
I recently applied this mod to my '00. I must say it works like gangbusters. The bike starts quicker and better than it has maybe ever. My only question is whether or not there are any long term side effects and what's the longest anyone has run with this mod? Has it caused anyone any problems?
jworth is offline
post #28 of 60 (permalink) Old 04-17-2013, 03:29 PM
Youngster
1stVulcan's Avatar
Another satisfied user of this mod! My bike had a very hard time starting before. I rebuilt the starter and saw some improvement but still would take a minute or two to get started sometimes so I opted to do this simple mod. So far my bike starts way quicker than before and I'm no longer embarrassingly sitting there trying to start my bike! Thanks for the post!
1990 VN750 Red and Black
Bought on 6/30/2012 w/ 13,230 miles
At ~20,000
To Do List: Paint Front Rim, Acct- mcct mod
Done: Adjusted Float Bowls, R/R Replace and Relocate, Coastered, Ear Shave, Front/Rear Tire Change, Replaced Final Gear Seals, Splines Lubed, Relay Coil Mod, Replaced Fork Seals, Rebuilt Starter
1stVulcan is offline
post #29 of 60 (permalink) Old 04-18-2013, 12:34 AM
Incubusgod2002's Avatar
Amazing difference!
So I just finished this mod and rode around for quite a while. It's like a completely different bike from how it ran before! It starts right up first try! The only silly thing i did at first was to attach the power wire to the starter side of the relay and it would only run with the start button pushed lol. Thank you fergy for the write up!
Incubusgod2002 is offline
post #30 of 60 (permalink) Old 05-16-2013, 06:08 AM
I made pick-up coil mod first, made only minor changes with engine start and running. After coil mod with relay engine starts just by looking at the start button First i have measured coils voltage drops, it was only 0,25V on hot side, but this drop made a big difference.
olaf is offline
