Eliminating headlight/horn/turn signal/ hazard box - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 02-24-2011, 05:28 PM Thread Starter
board917's Avatar
i want to remove and bypass the left handlebar control box, i will not be running a headlight switch, horn, or turn signals. If this control box is just unplugged from the wiring harness then the bike wont turn over. Anyone know which wire i need to short together? I am assumin it would be something with the headlight.
board917 is offline
post #2 of 25 (permalink) Old 02-25-2011, 04:02 AM
ok i didn't see this before i posted on your other less informative post. your problem is you are getting rid of the clutch safety switch. there is three wires going into it.. those three wires need to stay connected at the connector. All my manuals are packed away for my upcoming deployment and move afterwords, so i don't know the color or the bypass procedure for the switch... when in removed mine, i removed the jb and the ignition switch and the start button... so off the top of my head i don't remember.
post #3 of 25 (permalink) Old 02-25-2011, 12:24 PM
Connect JB 10-pin connector pin 12 (Y/G) to ground -> starts always, or connect it to pin 15 (LG) of the same connector -> only starts when in neutral.
pappa is offline
post #4 of 25 (permalink) Old 02-25-2011, 01:13 PM Thread Starter
board917's Avatar
there is no Y/G wire at the JB, #12 pin is a solid black wire, i connected that to ground and it didnt work. That black wire does run to the clutch safety switch tho.
board917 is offline
post #5 of 25 (permalink) Old 02-25-2011, 01:26 PM
b/w on the ignigtor box to ground with a diode in line is how I eliminated the switches
post #6 of 25 (permalink) Old 02-25-2011, 01:32 PM Thread Starter
board917's Avatar
wuts the purpose of the diode?
board917 is offline
post #7 of 25 (permalink) Old 02-25-2011, 01:35 PM Thread Starter
board917's Avatar
there is no Blue/White wire on the igniter box.
board917 is offline
post #8 of 25 (permalink) Old 02-25-2011, 01:36 PM
I am not sure why its needed... I tried just to go streight to ground and it would run as Long as I kept my finger on the start button, but as soon as I let go the engine would die.. I added the diode and it now runs fine.
post #9 of 25 (permalink) Old 02-25-2011, 01:51 PM Thread Starter
board917's Avatar
here is a pic of the wires i have to work with from the left control box and a pic of the wires i have going into the JB and igniter.
ID:	3402   Click image for larger version
board917 is offline
post #10 of 25 (permalink) Old 02-25-2011, 02:41 PM
The wiring diagram shows a Y/G wire from pin 12, but you don't seem to have anything at pin 12. If you grounded the black wire coming to pin 11 (connector front right corner in the picture), you should have blown a fuse! That one comes from the start button.
The starter circuit relay is supposed to get it's ground through pin 12, so I don't understand how you ever got your bike started. Or I've got the pin numbering all wrong, but the colors of the other wires seem to match the numbering the way I think it goes.
Edit:
You could try to bypass the starter circuit relay completely by connecting pins 11 and 13 together (that back wire in the front right corner to the yellow/red wire).
pappa is offline
