Battery Issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 02-20-2011, 07:16 PM Thread Starter
1986vn750's Avatar
Battery Issues
I believe I am in need of a new battery. This one is 4 (or 5) years old. Bought it from Advance Auto Parts. I see in some of your signatures, "MF Battery" what is that? How long do these batteries last? am I overdue? Is it worth the expensive $100 battery? or just buy the $40 one that i did 4 years ago. When i start it, my 12v meter drops to 4 or 5 volts, its weak, and it wont charge. once started via jumping, the system is at a steady 13v at 3,000 rpm. is that ok?
Thank you
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #2 of 20 (permalink) Old 02-20-2011, 07:27 PM
MF = Maintenance Free.. is it really worth it... I was very very skeptical of spending that kind of money on one, then I got a recommendation from one of the senior members to get one off of ebay for a lot less than I could get in the stores... got it, installed it, fixed a lot of issues i didn't even know I had, like hot start, then went out and bought a second one for my other bike. I will never use a conventional battery in any of my motorcycles again.
post #3 of 20 (permalink) Old 02-20-2011, 08:00 PM
Thank you
Your old battery is shot. The 13v reading when the bike is running is from the stator/alternator.
Here is a good MF-AGM battery at a current price of ~$61.
http://cgi.ebay.com/ebaymotors/Deka-...mZ270282472155
Technically it is a misnomer to call an MF-AGM battery "sealed".
It is Valve Regulated Lead Acid technology (VRLA), but the (gas) pressure relief valve is small and can be difficult to locate.
It is "sealed" in the sense that it will not spill liquid if it is tipped over.
For more info search VRLA and/or read this from Wikipedia:
http://en.wikipedia.org/wiki/VRLA_battery
post #4 of 20 (permalink) Old 02-20-2011, 08:04 PM Thread Starter
1986vn750's Avatar
I knew the 13v was from the bike's charging system, is that sufficient? i read somewhere that at 3,500rpm it should be 14.5v. is this true?
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #5 of 20 (permalink) Old 02-20-2011, 08:20 PM
13v from the charging system at 3,500 rpm seems low to me.
The electrical gurus do say 14.5 volts at 3500-5,000 rpm or so is desirable.
Does the voltage rise closer to 14 if you rev the engine higher to 4, 5 or 6k rpm?
A nominal 12 v battery has 6 cells that should produce 2.2 v each at rest, or 13.2 v total.
post #6 of 20 (permalink) Old 02-20-2011, 08:39 PM
Check your voltage again after you replace the battery. Your old battery may be dragging the voltage down.
And I agree about the MF battery. I bought one after all the recommendations here. Definitely makes a difference.
Desert Dog is offline
post #7 of 20 (permalink) Old 02-20-2011, 10:59 PM Thread Starter
1986vn750's Avatar
it does climb a little when reving, i think you're right, the very weak battery is pulling some of the juice from the charging system so it reads low (13v)
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #8 of 20 (permalink) Old 02-21-2011, 12:39 AM
[email protected] rpm, [email protected] rpm, 12.0-13 @ idle-2500 rpm
this is just a general rule of thumb. You know you have a bad battery, start there and worry about the R/R and stator after you get the battery fixed.
post #9 of 20 (permalink) Old 02-21-2011, 08:39 AM Thread Starter
1986vn750's Avatar
thanks, ordered a new battery last night from ebay. Ill give it to my dad as an early birthday present
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #10 of 20 (permalink) Old 02-21-2011, 10:25 PM Thread Starter
1986vn750's Avatar
How long has your MF battery lasted? do u keep it inside in the winter?
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
