Charging PROBLEM!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 02-13-2011, 07:58 PM Thread Starter
New Everything, Still no Charging!!!
Today I changed my stator and R/R and it still isn't charging. I have checked my grounds on the engine and on the frame. The 3 yellow stator wires are plugged all the way in and the R/R is plugged all the way in. All of the fuses are plugged in and good. I checked each of the 3 yellow wires for voltage where they plug into the harness for out put and each wire put out 8.9 volts, I checked the volts at idle and at 3500 rpms, nothing. I figure together they put out enough to charge?! I have no clue. Any ideas?
master-paul is offline
post #2 of 16 (permalink) Old 02-13-2011, 08:06 PM
You have to test the three yellow wires for AC voltage with the bike running and the three wires disconnected from the rest of the bike. I believe mine puts out around 20 VAC at idle and near 80VAC @ 5000 RPM
dariv is offline
post #3 of 16 (permalink) Old 02-13-2011, 08:20 PM Thread Starter
Is that per a wire or connecting all of them together?
post #4 of 16 (permalink) Old 02-14-2011, 04:04 PM Thread Starter
Mine checked out at about 78 VAC at 4500 rpms. I guess it is either going to be a wiring problem or a bad new r/r. I HATE WIRING PROBLEMS!!!
post #5 of 16 (permalink) Old 02-14-2011, 09:24 PM
78 VAC @ 4500 rpm sounds good to me... what is the battery voltage DC at idle, 1500 rpm, 3000 rpm, 4500 rpm, and 5000 rpm with engine cold then again with engine hot?
post #6 of 16 (permalink) Old 02-15-2011, 01:27 PM Thread Starter
Cold or hot and any rpm, starts off at 13.2 and starts falling until the bike dies.
post #7 of 16 (permalink) Old 02-15-2011, 03:07 PM
Member? ... check.
ZCraggRatt's Avatar
Electrical problems can be frustrating Paul. Just to be sure ... You have measured 78 VAC from each of the yellow stator wires to ground at 4500 rpm. right?
If that is true, then at least the stator seems to be in good working order.
On your next try, pull the two 10A fuses on the JB (headlight and taillight). Then, check for DC voltage at the R/R. Specifically, shove the probe in the top of the pin that is just at the locking tab of the R/R connector. It will be in the middle, and not yellow. This pin is designated as "M" in the schematics. I think the wire color will be brown. Document this voltage, and then do the same for the pin with the white wire. Check them at 2500rpm, and don't run the engine long. Let us know what you find after testing the R/R pins. Good hunting ...
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #8 of 16 (permalink) Old 02-15-2011, 03:24 PM Thread Starter
it will be a couple of weeks before I can mess with the bike again. Got things around the house to do but when I do I will start testing the r/r like you said. I am thinking it is between 2 things, the new r/r or wiring because the stator tested perfect. I turn down electrical problems on small engines all the time because the money isn't worth it. Thanks again for all the help.
post #9 of 16 (permalink) Old 02-15-2011, 04:21 PM
ok MP, here it is for you, the brown sensing wire on the jb isn't sensing a load. try jumping it to the wite wire on the r/r (or back to the battery) this should make it charge.
post #10 of 16 (permalink) Old 02-15-2011, 05:09 PM
Member? ... check.
ZCraggRatt's Avatar
Thanks for thew assist slimvulcanrider. I guess that would be (or back to the "+" terminal of the battery) ... right?
