Turn signal mount - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 02-10-2011, 04:24 PM Thread Starter
Papa Smurf's Avatar
Turn signal mount
Hi everyone. I got tired of my front right turn signal rubber stalk being cracked and bendy so I bought a new one. I will make a slight plug- Dark Horse got me the part for under $20 and I got it 3 days later. Not shabby.
I was just curious how difficult it is to replace. I did a search and found this:
"For the new complete ones, you simply disconnect the bullet connectors on the wires, remove the screw holding the signal on, turn the signal 90, and pull the whole thing out. Stick the new one in, turn it, screw it down, and hook up the new wires."
How hard it is to get to the bullet connectors? Am I going to be removing the tank?
Papa Smurf is offline
post #2 of 6 (permalink) Old 02-10-2011, 05:12 PM
No tank removal required here. I believe the connectors come together inside the head light housing. This is a fairly easy & quick job. It should take you about 20 min & that's if your taking your time. =)
post #3 of 6 (permalink) Old 02-11-2011, 01:53 PM Thread Starter
Papa Smurf's Avatar
Thanks. Tomorrow it is supposed to be 45 and sunny so if it took longer- I won't be freezing my fingers off.
post #4 of 6 (permalink) Old 02-11-2011, 06:04 PM
the connectors are in fact inside the headlight bucket. very easy to find. The hardest part might actually be a stuck screw... but still should only take 20-30 minutes. If every thing goes right... you should be looking at about 5 minutes
post #5 of 6 (permalink) Old 02-13-2011, 02:41 PM Thread Starter
Papa Smurf's Avatar
Well it took about 10. Interesting item for people doing this in the future (dunno if it is specific to the Dark Horse turn signal replacement or not)- the wires are different colors. The bullet connectors on the bike were white, black w/ white stripe, blue. The replacement was black w/ white stripe, black, red.
Took two tries, but I think the correct replacement wire colors (old to replacement) were: black w/ white stripe to black w/ white stripe, white to red, blue to black.
post #6 of 6 (permalink) Old 02-13-2011, 03:13 PM
the "new" lights weren't kawasaki specific. if it was a genuine kawa part, then colors would have matched. but glad to hear you got it fixed and working.
Tags
mount , turn signal
