Best AGM battery for the VN750...? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 01-26-2011, 08:08 PM Thread Starter
Drive less, ride more...
theauhawk's Avatar
Question Best AGM battery for the VN750...?
Per the following thread....
https://www.vn750.com/forum/showthrea...hlight=battery
...what company makes the Deka/MagnaPower battery mentioned? Is this battery made by the same company that makes the "Interstate" brand AGM (sealed) battery?
What service life on the VN750 can I reasonably expect from this Deka/MagnaPower sealed battery, given proper care? 3 years? 4, maybe?
Should I expect the same--or more--service life (and reliability) from the appropriate Interstate brand sealed battery, instead (even if it costs a bit more)?
I gather all the above mentioned batteries are in fact American made, too...right?
Anyone? Anyone?
'05 VN750
theauhawk is offline
post #2 of 14 (permalink) Old 01-26-2011, 08:50 PM
East Penn makes them:
http://www.dekabatteries.com/
This is battery our go-to guy lance328 recommends:
http://cgi.ebay.com/ebaymotors/Deka-...item3eee173adb
I`ve heard of guys getting 4 or 5 years from a MF-AGM battery, but a lot depends on your charging system, how/where you store the battery if you have long winter with no riding, etc.
post #3 of 14 (permalink) Old 05-17-2012, 12:40 PM
MrSkydriver
MrSkydriver's Avatar
Is this battery as good as the Deka ETX15L? CYTX14AHL-BS Interstate CYCLE-TRON II HIGH PERFORMANCE - 210 CCA - 12 AH
MrSkydriver is offline
post #4 of 14 (permalink) Old 05-17-2012, 12:44 PM
That's a YUASA, which is a great battery.
post #5 of 14 (permalink) Old 05-17-2012, 12:55 PM
MrSkydriver
Thanks thtanner!
post #6 of 14 (permalink) Old 05-17-2012, 05:57 PM
1994 VN 750
JBilko's Avatar
I've used Deka's for 3 years now without any problems! Great battery!
R/R Relocated
OEM Windshield
Stator Replaced
X Scorpion Voltmeter
Iridium Plugs
Splines Lubed
Throttle & Clutch cables replaced
OEM Sissy Bar/Backrest
JBilko is offline
post #7 of 14 (permalink) Old 07-23-2014, 03:13 PM
vulkan's Avatar
Saw this at Advance Discount Auto Parts Florida store...looks like the proper AGM battery that everyone is talking about.Not sure if its the correct size though,only $83.
vulkan is offline
post #8 of 14 (permalink) Old 07-23-2014, 03:26 PM
Dr. Vulcanstein
jadabull's Avatar
You've got the etx15, you need the 15L.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #9 of 14 (permalink) Old 07-23-2014, 05:33 PM
Both the Deka and Magna-Power brands are EXT15L.... so I image DAP's would be the same ?
post #10 of 14 (permalink) Old 07-23-2014, 09:53 PM
JM2001's Avatar
X2 Great battery. I wouldn't use any other.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
