Offroad light for headlight - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-17-2011, 11:32 PM Thread Starter
Diamondjim05's Avatar
Hello all, I have been thinking about this for a while, mainly due to the fact that I cant seem to find a decently priced headlight assembly with the right mounting ear, and I also like to do small custom touches that i havent seen before. My question is has anyone heard of or used a 6 inch offroad light as a headlight? I spent most of the night tonight fabbing up a bracket that would attach to the lower triple tree clamp bolts and mount a light in between the horns, giving me the option to use almost any single stud type mounted light as a headlight. I think this would do two things. One it would end my search for all the stuff i need to get a working factory headlight, and two it would add a little custom touch that i have not seen much. Let me know what you guys think, I will attach some pics to this post probably tommorrow when i get the cardboard mock up right. After that its off to the metal shop to get it cut and bent so i can paint it and hang it! On a side note, does anyone know the watt and amp draw of the factory headlight? I want to make sure I dont burn my bike to the ground if I get a light with to much draw.
Devin Mohler
Corporal, United States Marine Corps
1989 Honda Interceptor 500
1986 Vulcan 750, paid in full (250 bucks)
R/R Relocated (Thanks flitecontrol)
Splines Lubed
Battery Tender permanetly installed
Custom Seat
Planned mods and things:
Ear shave (using stock ears as storage)
Coastering
Wrapping exhaust
Custom Exhaust
Diamondjim05 is offline
post #2 of 9 (permalink) Old 01-18-2011, 07:44 AM
Just make sure you have a dual element bulb,or you could have a surprise on a dark night .
I could be wrong but I think the stock light is a 60 watt/50 watt combo high/ low rating at least the is what I had in my 750 with no ill effects.
post #3 of 9 (permalink) Old 01-18-2011, 11:02 AM
The manual calls for a 60/55W 12V H4 bulb for a 1986. I wouldn't go any brighter if you want to add anything else electrical to the bike.
1997 Vulcan 750
V & H Cruzers
K & N Filters in stock ears
silverback9 is offline
post #4 of 9 (permalink) Old 01-18-2011, 11:36 AM Thread Starter
No i dont think i will adding anything more to the bike, except for maybe a cigarette lighter type plug in for gps or something. I was also thinking of using the clear alternatives led kit for the brake light to free up some more power for a brighter light if i need to go that route. Does anyone have any ideas on what light to use? The bracket im making is for the single stud on the bottom type mounting, preferably 6 inch diameter. Thanks for the help yalls!
Devin Mohler
Splines Lubed
Custom Seat
Coastering
Wrapping exhaust
Custom Exhaust
post #5 of 9 (permalink) Old 01-18-2011, 02:57 PM
See this thread about a HID conversion. Especially note the Ebay link in lance328`s post #8.
https://www.vn750.com/forum/showthrea...hid+conversion
I`m not sure how this will work with a smaller headlight bucket that you are working on, but it may give you some more ideas.
post #6 of 9 (permalink) Old 01-18-2011, 07:59 PM Thread Starter
Here are some pics of the cardboard mock up, let me know what you guys think, the bolts on top of the mounting tab are just there for weight to keep the tab down since its just cardboard. Also, I found this light online, its pretty close to what im looking for.
http://www.demonscycle.com/Lights-an...-p6205748.html
Attachment 3340
Attachment 3341
Attachment 3342
Attachment 3343
Attachment 3344
Devin Mohler
Splines Lubed
Custom Seat
Coastering
Wrapping exhaust
Custom Exhaust
post #7 of 9 (permalink) Old 01-18-2011, 08:23 PM
here is a link to Drag specialties head light mounts that you can get some Ideas from
http://www.dragspecialties.com/part/...0light%20mount
this link doesn't appear to work ,just type in drag specialties and then click on 2011 catalog and then type in headlight mount
post #8 of 9 (permalink) Old 02-22-2011, 12:46 AM
look at my sig pic, I am running a 6" off raod light, with 55w and 150w h3 bulbs... I had to do a little modding to get the second bulb in, but it works great.
post #9 of 9 (permalink) Old 03-03-2011, 07:09 PM
Concert connoisseur
wib714's Avatar
ordered my hid conversion today that lance was using, anyone know if he ever got the write up done on it although it sounded basically plug and play.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
