new stator, RR, and still not working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-14-2011, 03:37 PM Thread Starter
Mississippi Rider
I replaced the stator, the RR, the battery, and the bike is still not charging. I charged the new battery correctly because I have done that several times over the years. I cant see how I could have hooked the stator or the RR up wrong. I can put it on the battery charger and watch the voltage fall as the bike is running. I suspect some type of serious ground problem, but cant find it. all the lights and guages all worked correctly. Bike runs fine. any body ever have a similar problem?
Matt79 is offline
post #2 of 11 (permalink) Old 01-14-2011, 03:47 PM
93VN750's Avatar
Did you use all stock/factory connectors and wiring? Did you check the voltage at the battery terminals from idle - 3500 rpm?
Was the R/R and stator new?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 11 (permalink) Old 01-14-2011, 03:56 PM Thread Starter
Mississippi Rider
new stock wiring and connectors, all new parts. I have only had time to check it at the battery. While the bike is idling the voltage is just draining away. I really didnt hold the rpms up. The next thing I plan to do is check the voltage at the stator wires, but one thing ive never understood is the role the two electrical doodads that are mounted inside with the stator. what are they and what do they do?
Matt79 is offline
post #4 of 11 (permalink) Old 01-14-2011, 04:04 PM
flitecontrol's Avatar
Was it a Ricks stator?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 11 (permalink) Old 01-14-2011, 04:49 PM
Member? ... check.
ZCraggRatt's Avatar
The two doodads mounted inside with the stator are the ignition coil pickups. Not related to charging system.
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #6 of 11 (permalink) Old 01-14-2011, 06:32 PM
The stator doesn`t charge at idle. The voltage will drop if only run at idle speed.
Check voltage again at 3500 rpm to see if it is charging.
post #7 of 11 (permalink) Old 01-15-2011, 12:54 PM
clock152's Avatar
Beat me to it!... and check your grounds.. all of em.
clock152 is offline
post #8 of 11 (permalink) Old 01-17-2011, 12:43 PM Thread Starter
Mississippi Rider
thanks guys for the info.. hopefully it will warm up enough for me to get it out and check some stuff. we had 8 inches of snow this past week and i live in mississippi.
Matt79 is offline
post #9 of 11 (permalink) Old 01-17-2011, 12:47 PM
Be sure to check the ground at the frame. Take it off and clean it. Some times it will be snug but not conducting electricity.
post #10 of 11 (permalink) Old 02-07-2011, 11:33 AM Thread Starter
Mississippi Rider
Bike is charging!!! I got it out yesterday and cranked it up and just put it on the battey charger and as usual the battery juice was just falling off. I drove the bike down the road for ten minutes and when I came back it was fully charged but as it idled the battery charge started falling fast again. And this was with all the fuses but the main pulled out. So I have a serious draw on the power somewhere.
Anybody have a schematic of where all the grounds are located? and any other suggestions would be great.
Matt79 is offline
