junction box click's - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 01-04-2011, 11:23 AM Thread Starter
sleeper's Avatar
not been on for a while, busy ,busy , busy.........problem as follows,
all I get when trying to start is a click from junction box (not starter relay)
replaced sarter relay and starter motor recently ( both no good)...battery needs replacing as it shows voltage but pushing no amps, could it be a possible blown capacitor in JB?????
cheers Chris
Front forks re-chromed
sleeper is offline
post #2 of 8 (permalink) Old 01-04-2011, 11:55 AM
There is a starter relay in the JB too. I think that is what is clicking.
You have enough voltage to operate the primary circuit switch, but not the current to spin the starter motor IMHO.
Try boosting the battery and see if that cures the problem.
I think you just need a new battery.
post #3 of 8 (permalink) Old 01-22-2011, 02:28 PM Thread Starter
sleeper's Avatar
new battery on today, still only clicking from junction box??????????
took JB off and cleaned connections and no change, still clicks (single )when button is pressed, any ideas on next possible step
cheers Chris
sleeper is offline
post #4 of 8 (permalink) Old 01-22-2011, 06:10 PM
The Professor
lance328's Avatar
cheers Chris
Test the starter solenoid.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 8 (permalink) Old 01-23-2011, 12:29 PM
Calif Rider
weh44att's Avatar
Try cleaning up all your grounds on the bike, especially the batterry ground to the bike.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #6 of 8 (permalink) Old 01-25-2011, 03:52 PM Thread Starter
sleeper's Avatar
tested measuring point 1 on starter circuit diagram and reading 12v, so starter relay not getting ground.....only groung wire I havnt cleaned up is one which is mid engine. next job after 4 days of work, also the grounding on starter motor to check. let you all know how i get on
cheers
sleeper is offline
post #7 of 8 (permalink) Old 02-23-2011, 01:52 PM Thread Starter
sleeper's Avatar
all the sugestions done, will start with screwdriver on starter relay no problem but on starter button original fault of clicking from fuse box.
possible next steps please
cheers
sleeper is offline
post #8 of 8 (permalink) Old 02-23-2011, 02:38 PM
If it starts with a screw driver then you have a bad starter relay, or a bad starter button... try grounding out the b/y wire on the starter solenoid.. if this works then its your start switch. If this doesn't work, then its the solenoid... also check to make sure you are getting power to the solenoid on the little white/red wire. If battery voltage isn't present, then you need a new JB.
