which to choose..... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 01-02-2011, 08:44 PM Thread Starter
Hey guys...
I am looking for a volt meter to monitor the battery..
i have seen the ones on ebay that use leds and the digital ones...
none seem that suited to the weather and vibrations of a motorcycle...
Has anyone found a good one? thanks...
Dave F is offline
post #2 of 5 (permalink) Old 01-02-2011, 11:05 PM
There are several mechanical gauges on this thread.
https://www.vn750.com/forum/showthrea...=LED+VOLTMETER
EDIT: Some overlap with the above link, but some new info included too.
https://www.vn750.com/forum/showthrea...+led+voltmeter
This is the link to the single light LED that VOIP Doc installed.
It has updated specifications for voltage readings, making it more useful for our bikes. Take a look.
http://www.cyclegadgets.com/Products...sp?Item=BOVOLT
I`m pretty sure there is a thread with a Kuryakyn multi LED gauge on here too, but haven`t found it yet.
Here is Daniel Meyers installation on his Valkyrie.
http://lifeisaroad.com/stories/2004/...Voltmeter.html
post #3 of 5 (permalink) Old 01-03-2011, 12:52 AM
KIMMERLING's Avatar
I have the kury led meter. Its ok but if you want exact numbers ..a digital readout would rock.
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #4 of 5 (permalink) Old 01-07-2011, 09:52 PM Thread Starter
thanks for the suggestions just got back from florida so i am now gonna check them out and when done will post a picture of the final result... if i can figure out how......
Dave F is offline
post #5 of 5 (permalink) Old 01-07-2011, 11:18 PM
cglennon's Avatar
Originally Posted by Dave F View Post
Hey guys...
Many internal dashboard based voltmeters will be fine with a gauge cup and little silicone sealant. That means lots of options to choose from depending on what look you want (i.e., match existing gauges, electronic look, etc.). Spend some time searching the picture gallery on this forum for the look you're after, then Amazon or Google for the specific parts.
Chris Glennon - Portland, OR
cglennon is offline
