main fuse keeps blowing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-23-2010, 04:08 PM Thread Starter
the 30 amp main fuse relay keeps blowing in the junction box my bike (well its actually a trike) is based on a 93 vn 750 also the starter relay was making a buzzing noise even when the ignition was turned off, any ideas??
cheers
blitzer is offline
post #2 of 8 (permalink) Old 12-23-2010, 10:07 PM
Just a stab at it but a short in the starter relay or the ignition switch...or the wire to them?
Try disconnecting possible causes and see if the fuse stops blowing. I had a bike that kept doing that and it turned out to be a bare wire grounding out in the headlight shell...but I would start with componets first.
post #3 of 8 (permalink) Old 12-24-2010, 11:05 AM
Now what
Ironman's Avatar
There's a wire harness that runs from one side of the bike to the other, under the seat. On my bike it had been tied down so tight, it was rubbing on the head of a screw. I loosened up the harness and fixed that problem.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #4 of 8 (permalink) Old 12-24-2010, 03:46 PM
Gemguy's Avatar
if the relay keeps buzzing then for sure it's either a stuck relay or a short in the wire running to it. good luck
~VROC~ # 389
Gemguy is offline
post #5 of 8 (permalink) Old 12-26-2010, 11:28 AM Thread Starter
cheers lads the starter relay and connections to it are in pretty bad shape so have ordered a new one once it arrives will sort out wiring as well
cheers
blitzer is offline
post #6 of 8 (permalink) Old 12-26-2010, 11:35 AM
You may also check the start button. It may be staying stuck.
Turn the emergency stop switch to off, see if that stops the buzzing.
post #7 of 8 (permalink) Old 12-26-2010, 12:29 PM
cheers
Disconnect the two small trigger wires (primary circuit connector) to the starter solenoid/relay, and attach some small jumper wires direct from the battery to test its function. If you hear a single click, it is probably still good.
For a definative test, disconnect the large cables leading to the battery and starter motor, and attach the leads of an ammeter to the relay terminals (secondary circuit). If you get a single click when applying power to the trigger circuit, and a reading of 0 (zero) resistance, the relay is good.
No click, or a reading greater than zero ohms indicates a faulty relay.
post #8 of 8 (permalink) Old 01-02-2011, 03:00 PM Thread Starter
replaced the starter relay and is working perfect now, only 7.50 (euro) on ebay
blitzer is offline
