running light wire... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 12-12-2010, 01:57 PM Thread Starter
Finally riding again!
Norm's Avatar
I noticed that my rear running lights are not on...(used bike long story) and found the wires that control them spliced together coming from the lights. If I touch those to the positive term. of battery the come on but cant find the wire in the wiring harness that will control them. Where should I look?
Norm
'93 750
Left to me by a great friend who just passed away.
Norm is offline
post #2 of 6 (permalink) Old 12-12-2010, 02:22 PM
First off the rear turn signals are not running lights, only the front ones are. The rear tail light of course functions as a rear light and brake light. There is a set of wires under the seat that runs to them, and I belive the turn signal light branch off from that.
There is no grounded lights , meaning the lights use a wired ground. There should be three wires going to the tail light and two to each turn signal.
There should be a wiring chart somewhere in the photo section that will help you identify the proper wires.
Lets just hope the previous owner did not rig up something stupid for you to figure out.
post #3 of 6 (permalink) Old 12-12-2010, 03:58 PM
if your rear turn signal have three wires, then the PO put front turn signals for rear turn signals... if you want to make them a running light as well, splice into the blue wire running to the tail light.
post #4 of 6 (permalink) Old 12-12-2010, 04:01 PM
You will need to use a red lense on them for the rear.
post #5 of 6 (permalink) Old 12-12-2010, 06:43 PM
Good point there!
post #6 of 6 (permalink) Old 12-18-2010, 10:46 PM Thread Starter
Norm's Avatar
I do believe they are aftermarket so they might be fronts...will check out the splicing option...Thanks to all....
Norm
'93 750
Norm is offline
