stator wires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 12-12-2010, 02:42 AM Thread Starter
stator wires
i had to buy a used wiring harness off ebay because the stock one had been hacked up by the previous owner well i have everything hooked up and working besides the stator from the harness there are 3 yellow wires with bullet style connectors and the 3 yellow wires coming from the stator have been cut how can i figure out which wires connect to each other
mtcrss546 is offline
post #2 of 4 (permalink) Old 12-12-2010, 03:02 AM
Now what
Ironman's Avatar
It doesn't matter. I'd cut out the bullet connectors, slip a piece of shrink tubing over 1 of each wire pair, solder the ends and seal it with the shrink tubing. That's what I did a couple of years ago and they've been fine ever since. Don't bundle them tight together, though. It's good to have air flow between them.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #3 of 4 (permalink) Old 12-12-2010, 03:08 AM
It doesn't matter which of the stator wires hook to each of the harness connections .Just make sure all three are clean and have a good solid connection,they are the three ac legs that have to go through the RR to change to DC for your battery charging duties.
And Ironman gave you good advice. I ran mine that way too.no worries about loose connections or heat build up.
There you go,closer to finished than you thought ,Huh?
post #4 of 4 (permalink) Old 12-12-2010, 08:41 PM Thread Starter
ok thanks for the advice this is the best forum iv been apart of yet
