Wonder if I did something wrong - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 11-30-2010, 09:09 AM Thread Starter
Wareagle1970
carolesteven's Avatar
Good morning everyone.
Sunday night I re-installed my left side grip on my bike, this time using golf grip and lighter fluid, and it is tight as can be.
At the same time I pulled the connection from R/R and put some dielectric grease on the male connector, then reattached
to the R/R. Wiped off any excess grease, then wrapped the whole connector with electric tape for good measure. Attached
it back to my battery tender and left her alone until this morning. It is in the low 40's here, so I decided to ride. When I
went to start it didn't sound like she had full cranking power. Am worried now that I messed something up... Does any of
what I have said sound like I could have cause a potential issue? I meant to check the light on the battery tender before
I removed the cable this morning to see if it was green, but completely forgot.
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 15 (permalink) Old 11-30-2010, 09:54 AM
Daily rider
ksmnet's Avatar
Can't imagine you would have messed anything up, unless you yanked loose a connection somehow in working with the R/R connector. Putting grease on it for electrical connections will not hurt, but will keep it from corroding. Could be just a fluke, and something else is wrong. Hard to say.
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
post #3 of 15 (permalink) Old 11-30-2010, 10:18 AM Thread Starter
Wareagle1970
will check the voltage when I get home...
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 15 (permalink) Old 11-30-2010, 10:53 AM Thread Starter
Wareagle1970
On the R/R which is the icon for this group, there appears to be a ground wire coming out of the harness. Mine does not have that, only the plug that connects to the r/r. Should there be a ground that goes to the chassis/frame?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #5 of 15 (permalink) Old 11-30-2010, 11:54 AM
flitecontrol's Avatar
One of the wires to the r/r is a ground, so you don't need a separate ground wire.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 15 (permalink) Old 11-30-2010, 12:10 PM Thread Starter
Wareagle1970
Ok, so the plug from the harness to the r/r has the ground built in...
I put dielectric grease on the mail end of the connection and attached the r/r, then wrapped with electric tape as an extra measure. Should be good to go, right?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #7 of 15 (permalink) Old 11-30-2010, 01:07 PM
Calif Rider
weh44att's Avatar
I would say it was the low 40's that will affect the starting of the bike. Plus how old is the battery and is it one of the higher CCA batteries. This is not good to say but with my bike with out a real good charge, my bike would not crank over fast enough to get it started in that cold temperatures. My bike sets outside covered, but not in a garage.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #8 of 15 (permalink) Old 11-30-2010, 01:20 PM Thread Starter
Wareagle1970
Mine stays in the garage and when I park it I always hook up my Battery Tender.
Kuryakyn ISO Grips
coastered
Hickory, NC
post #9 of 15 (permalink) Old 11-30-2010, 09:18 PM
If your battery is the least bit weak you may have trouble starting in colder temps.
If you need a new one look for a Maintenance Free- AGM like this one.
http://cgi.ebay.com/ebaymotors/Deka-...item3eee173adb
post #10 of 15 (permalink) Old 11-30-2010, 09:42 PM Thread Starter
Wareagle1970
Thanks Hoss...
Kuryakyn ISO Grips
coastered
Hickory, NC
