R/R relocation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-22-2010, 01:32 PM Thread Starter
Wareagle1970
carolesteven's Avatar
R/R relocation
Hey everyone!!!
Friday night I relocated my r/r and have a question. Has anyone put some sort of protective boot over the wiring harness connection point? If not and you went the route of putting dielectric grease on it instead, do you put this grease on the male and/or female connection? I have never used dielectric grease before and wanted to be sure I used it properly.
Thank you in advance,
Steven
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 6 (permalink) Old 11-23-2010, 01:19 PM
Nope. I just angled my downward as water would naturally run out if any got in. You figure where it was sitting. Nasty spot, Alot have used the grease & that should be enough of a protectant. Do you have a pic of how yours is mounted/
post #3 of 6 (permalink) Old 11-23-2010, 01:20 PM Thread Starter
Wareagle1970
No, not yet, but will try to take one and post it.
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 6 (permalink) Old 11-23-2010, 03:44 PM
KIMMERLING's Avatar
I greased it with dielectric...just enough to goop up the connections...then electric taped the whole thing...
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #5 of 6 (permalink) Old 11-24-2010, 12:28 AM
Steven
On a single wire connector you pack the female side, then plug in the male pin.
On a multiple wire connector you pack the male pin connector with grease, then plug in the female side and also pack the back end of the connectors.
Wipe any excess grease off the connectors, and reseal with dielectric grease anytime the connectors are separated.
Here is a link to automotive use of the grease on youtube. It is generic in nature, not specifically pointed towards use on a motorcycle.
http://www.youtube.com/watch?v=8W7o-CRRmGo
post #6 of 6 (permalink) Old 11-24-2010, 08:54 AM Thread Starter
Wareagle1970
Thanks for your help Gordon. Will take care of that tonight.
Kuryakyn ISO Grips
coastered
Hickory, NC
