new Stator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 11-15-2010, 08:43 PM Thread Starter
new Stator
hi I have a question..
I believe i too am in dire need of a new stator as my bike
charges at a low rate and slowly dies usually at a gas station...after a long drive.. Somewhat embarrassing but its a good thing the bike looks so good...
its an 85 vulcan 750...anyhow i found a stator by rmstator that states it produces 20 percent more power then the original.. which should be enough by my calculations... its 119 dollars.. and brand new..
rmstator.com/en/motorcycles/suzuki/vn_750_vulcan/stator/stator_for_kawasaki_vn_750_vulcan_/4240.htm
Has anyone changed the biggest power suckers on these bikes .. theheadlight to a hid bulb? heres the link i would appriciate your opinions on it.. Btw the i did the timing chain adjuster fix and it worked great...
thanks
Dave F is offline
post #2 of 8 (permalink) Old 11-15-2010, 10:05 PM
You want a Tim Perret rebuilt stator.
http://cgi.ebay.com/ebaymotors/motor...Q5fAccessories
HID conversion - read this thread for more info. Note lance`s post #8 for ebay link to best kit.
https://www.vn750.com/forum/showthrea...ght=conversion
post #3 of 8 (permalink) Old 11-15-2010, 10:32 PM
flitecontrol's Avatar
X2 on the TPE stator. Everything else except the Kawi stock stator is not worth the $. The TPE rebuild is better than stock.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #4 of 8 (permalink) Old 11-19-2010, 10:46 AM Thread Starter
ok thanks for the info. guys..
i was now wondering if i changed the lights to leds and the headlight to an hid...
if the current draw would be cut down enough so that the stator wouldnt really need
changeing..thus saving me the work... so i can play with other things on the bike...
any opinions?
thanks
dave
Dave F is offline
post #5 of 8 (permalink) Old 11-19-2010, 10:50 AM
The stator needs to be funtioning properly. Reducing the load isn't going to have much, if any, affect. Have you run the stator test described in this forum to be sure it's bad??
"Black Beauty"
Old Blue
post #6 of 8 (permalink) Old 11-19-2010, 11:01 AM
Cheman's Avatar
3x on the TPE stator
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
post #7 of 8 (permalink) Old 11-20-2010, 10:19 AM
99 VN750
satcer's Avatar
Hi, to solve my bike electrical issues, first I change my R/R and relocated it, second change stator, and finally change the baterry for a sealed mainteinance free one.......
Until then I finally enjoy riding my bike.......no more hassle starting it at all and it runs great........
In the electrical forum you will find all the information you will need.......
suerte!
satcer is offline
post #8 of 8 (permalink) Old 11-25-2010, 07:29 PM
GIMPYRDR's Avatar
Ok, I know answering this will bump it up, but I just went through the stator replacement. I suggest TPE also. $69.95 + $14.00 shipping and that's what you send him. Pay $4.97 flat rate box at the post office and send it off to TPE with the above price quote. His web site is www.tpe-usa.com. Oh, I metered the stator after I got it back in and at 3k rpm was getting 14v at the battery. That is better than the stock when I metered at approx. 9000 miles just doing a PM check.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
