R/R replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-03-2010, 04:12 PM Thread Starter
R/R replacement
So I checked my R/R and it looked to be bad (i.e. none of the values were within spec). So I ordered a replacement off of ebay. I checked it today and again all the resistances were in the Mega-ohm range. Did I get a bad one or are the expected values Mega, not Kilo-ohms?
mbeluthier is offline
post #2 of 4 (permalink) Old 11-03-2010, 06:07 PM
I just checked the chart in the Clymer manual and about half of the resistance specs are infinite, or open. Is that what you are calling mega-ohms? Do you have a manual?
post #3 of 4 (permalink) Old 11-03-2010, 08:00 PM Thread Starter
I do have a manual. So specifically the leads that should be a few hundred ohms are not even close to that. I called the guy I got it from and he said I should try it out on the bike first and check the voltage at the battery. Does the R/R need to be grounded to the frame through the attachment bolts to do that or can I just connect the connector. Sorry for all the questions.
Thanks
post #4 of 4 (permalink) Old 11-03-2010, 10:30 PM
Just plug it in and run the bike. It does not need to be grounded to the bike. Check for good voltage 14 volts at about 3 or 4k rpms.
