Signals work, but no Running Lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-22-2010, 02:07 PM Thread Starter
Hey Guys,
I noticed a problem when I was riding last night. It seems that the left side running lights no longer light up. The front and rear turn signals work, but just in running light mode they don't. I haven't checked the light bulbs yet, but I'm assuming that since both are out it's something a bit more complicated. Thanks for any insight.
-M
mbeluthier is offline
post #2 of 11 (permalink) Old 10-22-2010, 03:20 PM
Originally Posted by mbeluthier View Post
Hey Guys,
-M
only the front has dual element bulbs ,check your front bulb ,the rear is a signal only.
post #3 of 11 (permalink) Old 10-22-2010, 04:10 PM
x2 ^^^
post #4 of 11 (permalink) Old 10-22-2010, 10:14 PM
baldy's Avatar
X 3 ^^^^^
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 11 (permalink) Old 10-23-2010, 04:45 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
However, if you change out your stock bulbs for LED's you can make the rear full time running lights and brake lights, too as well as turn signals. It's nice to be seen.........
Chris and Shim is offline
post #6 of 11 (permalink) Old 10-23-2010, 10:28 PM
Not without adding wires from the running light, brake light circuits.
post #7 of 11 (permalink) Old 10-24-2010, 02:50 AM Thread Starter
Thanks for the help guys. I'm a bit green when it comes to my bike. For some reason I thought the rear were running lights, but now that I know they're not, I'm going to work on figuring out how to make that happen. Thanks again!
post #8 of 11 (permalink) Old 10-24-2010, 03:40 AM
to make the rear running lights as well, you need to either get a set of front turn signals,and run the third wire to the tail light.
post #9 of 11 (permalink) Old 10-24-2010, 08:28 AM
check your state laws concerning rear lights,I believe that amber running lights are for front use only in most states on motorcycles.
post #10 of 11 (permalink) Old 10-24-2010, 04:24 PM
True, merely changing to LEDs doesn't make the rear ones running lights. I guess what I wrote could be interpreted that way. Yes, you also have to install another component. But doing so is worth it to make it full time running, brake, turn etc.
