Bypassing headlight - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-18-2010, 11:07 PM Thread Starter
1985 VN-700
L2fish's Avatar
Bypassing headlight
I know its a law in most states, but has anybody bypassed their headlight during for starting? I remember when I got my 750 the stator was weak at best and the bike would run 2 minutes after jumping. The guy got stranded, so the get it home I disconnected the headlight. I sucked my battery down the other morning trying to start this friggin Vulcan POS. It happens all the time after the bike has sat a few days. So im thinking of putting in a switch so I can shut the headlight off when starting to save a little energy. Im gonna rebuild the starter this winter, check all the connections, and hot the coils like the post I saw in here.
L2fish is offline
post #2 of 12 (permalink) Old 10-18-2010, 11:09 PM
Mine does have a switch monted in the top of the headlight to turn it on and off. It came that way but it is handy. Also when it is off the white headlight panel switch lights to remind you that it is off.
2001 Vulcan VN750
Custom Paint
MCCT Conversion
Baffles Removed
K&N Filters
Saddlebags
Pirelli MT 66 Tires
scottmotorsports is offline
post #3 of 12 (permalink) Old 10-18-2010, 11:31 PM
'93 VN 750
CDUB's Avatar
I recently hooked up a simple switch on mine and it works great! Before doing any "wiring" I moved the blue wire in the JB plug over to the empty spot next to where it is stock because my headlight relay went bad. This gives it constant power when the key is on. Then I spliced a wire into the blue wire just a couple of inches after it comes out of the JB. I ran the spliced in wires up along the frame, under the tank and out the front. I cut a hole in the plastic cover and installed a simple ON/OFF switch and connected the wires. Now with the switch in the OFF position I can start the bike without the headlight being on. It doesn't matter if the beam switch is in Hi or Low, when the switch is OFF the headlight is OFF. Now I just have to remember to turn it back on before I ride.
93 VN750
Cobra exhaust
R/R Relocation
35k mi
CDUB is offline
post #4 of 12 (permalink) Old 10-19-2010, 09:57 PM Thread Starter
1985 VN-700
L2fish's Avatar
Cool thanks. My stator is has about 15K on it Im wondering if its not up to par. But I only have trouble in the cold weather. So I looking for all the starting juice I can get.
L2fish is offline
post #5 of 12 (permalink) Old 10-19-2010, 10:22 PM
baldy's Avatar
And remember to turn it off after riding so not to defeat the purpose and still wind up with a dead battery. lol
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #6 of 12 (permalink) Old 10-19-2010, 10:24 PM
baldy's Avatar
How new is the battery? I'm thinking the battery is more likely to cause a hard start in colder temps then the headlight being on.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #7 of 12 (permalink) Old 10-19-2010, 10:46 PM
i agree with baldy.. I had the same problems until I installed a AMG battery
post #8 of 12 (permalink) Old 10-20-2010, 09:03 PM
A new AGM battery is the way to go...although, you could just hook up a easy to plug in battery charger. If your bike has been sitting awhile....You just start the bike and then .....unplug the charger....
But ...an AGM battery will hold a decent charge for a many weeks. I think I would go there first, then pick a charger.
You should of course check the charging system before spending any green on anything.
post #9 of 12 (permalink) Old 10-20-2010, 11:17 PM Thread Starter
1985 VN-700
L2fish's Avatar
Battery is a NAPA beginning of this summer. I had a loose connection problem with my stator leads. But hey were still putting out 60 volts after the fix. But, my fuse box and connections dont look that good, so I could probably use some work there. The main fuse is real loose. I crimped the blades to fit tighter. Still kinda not so good, but fine all summer. If the thing doesnt fire off within 20 cranks im usually having to jump it. This bike has always been this way. I feel the battery is too small for these bikes as well as being in a bad place. Vulcan electrical systems are a real POS just look at all the posts. Im also gonna run some 10 gage wire off the battery to the inside the side cover or the tool box so its easier to hook up a charger.
L2fish is offline
post #10 of 12 (permalink) Old 10-20-2010, 11:20 PM
flitecontrol's Avatar
With AGM and iridium plugs, mine starts the first lick unless it is near or below freezing.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
