led lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 10-10-2010, 10:47 PM Thread Starter
Journey's Avatar
led lights
looking at dropping the electrical load on my 95 vn 750. would replacing the turn signals and brake lights help at all. also any ideas on best prices etc,
My Enuf.
1995 Vulcan 750
New wires and plugs
Removed and cleaned carbs
re routed air line to right ear
re built transmission
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #2 of 14 (permalink) Old 10-10-2010, 11:13 PM
IMBoring25's Avatar
Haven't done the turn signals on mine, but as far as the brake light goes, while it's not the least-expensive way to go, I would highly recommend the Clear Alternatives LED panel.
IMBoring25 is offline
post #3 of 14 (permalink) Old 10-10-2010, 11:28 PM
dirtrack650's Avatar
I like LEDs but don't recommend doing the turn signals for two reasons: LEDs are directional and our turn signal lenses work better with filament bulbs (broader visibility). Also, turn signals are not a constant drain on our system so there's no real savings of power.
The brake light/running light conversion to LED can save you some watts. I've done it with the cheaper 1157 LED bulbs with good, not great results. Remember, every time you brake, you're using 54 watts of power.
1157 LED bulbls:
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 14 (permalink) Old 10-11-2010, 02:16 AM
2 years ago I picked up 4 LED, 1157 bulbs with 6 rear facing LEDs and 6 facing outward around the circumference. dirtrack, these should be better than your "good, but not great" 1157 bulbs, that all face the rear. I only paid $3 apiece for them, so was willing to gamble on their utility. Unfortunately they are unbranded and I got them from the surplus section at Princess Auto, so I can`t tell you where to find any more like them.
We will have to keep our eyes open for some brand name LED bulbs styled like this that are widely available, or online from somewhere like Clear Alternatives or Custom Dynamics.
post #5 of 14 (permalink) Old 10-11-2010, 11:00 AM
flitecontrol's Avatar
Something like this? http://cgi.ebay.com/ebaymotors/1157-...item27b4f74a2b
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 14 (permalink) Old 10-11-2010, 12:32 PM
cglennon's Avatar
I did all 4 turn signals, brake/running and made a second brake only signal (mounted on back of the sissy bar) using Radiantz 1.85" Dual Intensity clusters.
Very bright!
Radiantz clusters retail for $24/piece, but they show up from time to time on eBay, where I got mine for $5/piece.
The license plate light uses a small LED panel purchased on eBay for $5. I used the old bulb bases, after gutting them, along with a small loop of coat hanger wire and silicone adhesive to connect the LEDs. Easy plug-n-play, just like a regular incandescent bulb.
Chris Glennon - Portland, OR
cglennon is offline
post #7 of 14 (permalink) Old 10-11-2010, 01:28 PM
Originally Posted by flitecontrol View Post
Wow, those are impressive fc, and inexpensive too. Looks like 9 rear facing and 3 rows of 9 side facing LEDs on those. Three times the total number of LEDs that mine have. Mine are arranged all on one level, positioned like numbers on an analog clock face, with alternating 6 rear and 6 circumference facing LEDs.
A question for cglennon. Why are your brake lights so yellow? Are the Radiamz Clusters amber? I can even see little amber colored light dots in both of the brake lenses in the pics taken in the daylight.
post #8 of 14 (permalink) Old 10-11-2010, 02:17 PM
cglennon's Avatar
I used amber clusters in the turn signals and red in the brake/running and second brake light. However, both the amber and red clusters appear clear when powered off. The yellow dots you see behind the red brake/running lens is the camera's flash bouncing off the clear individual LEDs in the cluster. The brake/running are actually super red when on, but the brightness overwhelmed the sensor in my camera causing the color to appear yellowish.
cglennon is offline
post #9 of 14 (permalink) Old 10-11-2010, 02:31 PM
OK, thanks for the explanation Chris. That makes sense to me now.
post #10 of 14 (permalink) Old 10-11-2010, 05:19 PM
Drive less, ride more...
theauhawk's Avatar
CG, thanks much for your post, above......!
Can you comment and/or illustrate how bright your LED turn signals are in bright sunshine/broad daylight (especially in summertime)?
Also: do they show up well from the sides (even in the above described conditions)?
Finally--how well did your Radiantz clusters fit inside the turn signal stalks? Did you have to modify them--and if so, how much?
I'm sure most here would much appreciate this sort of feedback from you....
'05 VN750
theauhawk is offline
