headlight/eng. rev? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-08-2010, 11:43 PM Thread Starter
headlight/eng. rev?
deleted
FlacoLove is offline
post #2 of 6 (permalink) Old 10-09-2010, 02:22 AM
Everything is normal, the voltage just is a bit lower at idle.
The warning light is supposed to glow dimly when everything is ok.
Even the 2$ flasher is fine, there is no need for the OEM flasher.
pappa is offline
post #3 of 6 (permalink) Old 10-09-2010, 06:08 PM
I agree with pappa. At idle the system is not charging, so you are just running at battery voltage. As the rpms increase so does the voltage up to ~14 V give or take 1/2 a volt.
As I recall, my headlight dash warning light glows dimly too, so your`s sounds normal.
I don`t know anything about the electrical difference between the OEM 3 prong flasher and the 2 prong replacement, but for the $78 difference in price I would have saved my money.
post #4 of 6 (permalink) Old 10-09-2010, 10:11 PM
dirtrack650's Avatar
I don't think your emergency flashers will work with a 2 prong - please advise...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 6 (permalink) Old 10-09-2010, 11:25 PM Thread Starter
deleted
post #6 of 6 (permalink) Old 10-11-2010, 01:55 PM
Signals Blink Slower
The reason the automobile flasher blinks slower is that it is designed for a heavier load of lights. The load heats up a medal reed that retracts when warmed, breaks the circuit, cools, then makes the circuit again, repeat until switched off.
w4nmh is offline
