Signals don't work - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 10-08-2010, 05:44 PM Thread Starter
flitecontrol's Avatar
Signals don't work
I had a rear signal crack on the rubber. Inserted a metal tube and JB Welded it together. Weld cracked, wires rubbed against tube and shorted out. All the blinkers quit working. Checked the fuses, they're OK. Replaced signal with brand new one. The blinkers still don't work. I can hear a faint "click" around the headlight area (I think, may be around the neck covers) when I use the blinker switch.
Any suggestions on how to fix this?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #2 of 17 (permalink) Old 10-08-2010, 05:47 PM
cglennon's Avatar
Maybe the flasher unit has blown. $10 at the auto parts store.
Chris Glennon - Portland, OR
cglennon is offline
post #3 of 17 (permalink) Old 10-08-2010, 07:30 PM Thread Starter
That's what I was thinking. Where is it located? Found one reference to battery box, is that correct?
"Black Beauty"
Old Blue
post #4 of 17 (permalink) Old 10-08-2010, 07:41 PM
MANIC MECHANIC
vulcanjoe's Avatar
the flasher looks like a relay with 3 wires attached to the battery box
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 17 (permalink) Old 10-08-2010, 08:05 PM
I don`t understand what could be clicking around the headlight or neck covers when the signal relay is behind the battery???
post #6 of 17 (permalink) Old 10-09-2010, 09:52 AM Thread Starter
Me too, but comprehending electrical issues is like trying to understand quantum physics to me.
"Black Beauty"
Old Blue
post #7 of 17 (permalink) Old 10-09-2010, 11:46 AM
cglennon's Avatar
It could still be the flasher unit. The geometry of the bike frame and gas tank might be channeling the noise forward (I'm assuming the engine was off when the clicking was heard). Only way to tell for sure is to pull the seat and disconnect the flasher unit to see if the clicking goes away.
cglennon is offline
post #8 of 17 (permalink) Old 10-09-2010, 11:53 AM
Vintage bike addict
antiq's Avatar
First you might want to check all the bulbs and fuses. If one side lights even faintly it may be a bad ground.
Eleanor Roosevelt.
antiq is offline
post #9 of 17 (permalink) Old 10-09-2010, 01:00 PM Thread Starter
Everything worked until the wires frayed. I even tried moving the 10 amp fuses from one location to another. All the grounds were tightened with threadlocker not long ago, but I can check. The lights don't do anything, even faintly.
"Black Beauty"
Old Blue
post #10 of 17 (permalink) Old 10-09-2010, 04:31 PM
lights don't come on at all?
