electrical mystery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-07-2010, 03:45 PM Thread Starter
jscucci
electrical mystery
today I went to start my bike and none of my electrical works except the turn signals. no horns, no tach,no headlight, no brake light, and nothing on the pilot box. the only things working are the turn signals. the bike starts and runs fine. any suggestions?
jscucci is offline
post #2 of 11 (permalink) Old 10-07-2010, 04:02 PM
Ceal's Avatar
Obvious question: Did you check the fuses?
Ceal is offline
post #3 of 11 (permalink) Old 10-07-2010, 04:12 PM Thread Starter
jscucci
yes all of the fuses are good...possibly a bad junction box?
jscucci is offline
post #4 of 11 (permalink) Old 10-07-2010, 04:28 PM Thread Starter
jscucci
the fan works to
jscucci is offline
post #5 of 11 (permalink) Old 10-07-2010, 04:57 PM
Ceal's Avatar
I'm not great with electrical systems, but I think there's a procedure to testing the junction box in the manual. If it's not fuses or the junction box, most likely culprit that I can think of is some of the wiring is shorted. But like I said, I'm not great with electrical systems, someone else should chime in soon.
Ceal is offline
post #6 of 11 (permalink) Old 10-07-2010, 05:59 PM
Addicted to Projects
bullwinkle's Avatar
Check and make sure the key switch isn't the problem. Wiggle it and put some slight pressure on the ignition. Sometimes the switch wears out.
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #7 of 11 (permalink) Old 10-07-2010, 06:00 PM
Ceal's Avatar
Oh yeah... mine did the opposite because of the switch, everything turned on but didn't crank unless I found "the sweet spot".
Ceal is offline
post #8 of 11 (permalink) Old 10-07-2010, 08:53 PM
baldy's Avatar
Also pull the headlight out and check the plug connectors in there.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #9 of 11 (permalink) Old 10-08-2010, 04:23 PM
Check the connections at the neck covers
post #10 of 11 (permalink) Old 10-09-2010, 12:56 AM
Under the left neck cover, look for a 'bullet' (single) connector (near the other electrical connector blocks) that has a brown/white wire going to it. Check the condition of this connection. (and the rest of them while your in there) Also, with the key in the 'ON' position, you should have ~12VDC at the br/w wire.
......... thou the br/w doesn't have anything to do with the headlight....... it does control the gages, brake sw, and horn.
dariv is offline
