Is it normal...? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 09-29-2010, 08:57 PM Thread Starter
Ceal's Avatar
Is it normal...?
I hooked up my battery to a Battery Tender Jr. It has been charging for around 1.5 days now (I killed the battery) and today I noticed that something leaked and it seems like battery fluid came out... is this normal or is something weird going on here? I checked the level and it's still between the two lines, so it's fine I think. Don't have a voltmeter on hand to check anything though.
Ceal is offline
post #2 of 20 (permalink) Old 09-29-2010, 09:06 PM
batteries leak do to over chargeing sometime, but i can't see a battery tender doing that unless it is faulty
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
post #3 of 20 (permalink) Old 09-29-2010, 09:18 PM Thread Starter
Ceal's Avatar
Any way I can test if it's faulty?
Ceal is offline
post #4 of 20 (permalink) Old 09-29-2010, 09:59 PM
The Battery Tender Junior is only rated at 0.75 amps, and does have an electronic brain that puts it into float mode when the battery is fully charged. Shouldn`t be able to overcharge. More info here:
http://batterytender.com/battery-ten...-at-0-75a.html
If any acid spilled on your bike rinse it off asap. With no meter it is hard to check the battery or the tender. Try starting the bike. It won`t tell you the voltage, but will let you know if the battery is charged.
post #5 of 20 (permalink) Old 09-29-2010, 10:17 PM
Concert connoisseur
wib714's Avatar
baking soda may neutralize that spill too.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 20 (permalink) Old 09-29-2010, 10:49 PM
cglennon's Avatar
Originally Posted by Ceal View Post
.. (I killed the battery)..
Wet cells, even AGM type, do not like to be completely discharged. There are all sorts of tests you can do, but if the battery is more than a few years old, then consider replacing it. Buy a good AGM battery and don't let it completely discharge.
Chris Glennon - Portland, OR
cglennon is offline
post #7 of 20 (permalink) Old 09-29-2010, 10:55 PM
don't know how to measure amperage, but you can cheack the output voltage.
custom exhaust
rear frame chopped
airbox removed
hzhardy is offline
post #8 of 20 (permalink) Old 09-30-2010, 01:07 AM Thread Starter
Ceal's Avatar
Well I got a multimeter from a friend tonight, I checked the voltage with the tender connected and it was at 14.14V I disconnected it and I'll check the voltage after I have some dinner and see if it's keeping the charge.
Ceal is offline
post #9 of 20 (permalink) Old 09-30-2010, 03:21 AM Thread Starter
Ceal's Avatar
After a couple hours, I checked the voltage and it's at 12.69V The tender never changed to "storage mode" though, it just keeps charging. Is that a normal voltage for a good battery?
Ceal is offline
post #10 of 20 (permalink) Old 09-30-2010, 03:22 AM Thread Starter
Ceal's Avatar
Oh and the AGM battery is definitely on my list of things to get in the near future, I just thought other stuff like fixing the brake cylinder is more important for now.
Ceal is offline
