Working on the stator, couldn't figure this out from the other threads - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-28-2010, 01:13 PM Thread Starter
nickamudd's Avatar
Here are the facts:
1. Engine off, battery voltage 12.5-12.6
2. Idling, battery voltage 11.6-11.9 (Increases with rpm)
3. Tested the yellow leads coming from the stator- NOTHING
4. All lights and gauges are working.
5. As the bike runs, battery slowly but surely drains
So my question is, if the stator isn't working at all, giving 0 volts, then how are the headlight, highbeam, signals, etc. still working and why is the battery voltage increasing with rpm? If it's completely dead then all that should not be happening, right?
Or am i just testing it wrong? I tested yellow lead to yellow lead for all 3 and got absolutely nothing with the voltage meter set to 200 volt range dc.
Thanks,
Nick
nickamudd is offline
post #2 of 7 (permalink) Old 09-28-2010, 01:36 PM
I think that is ac current coming out of the stator.
post #3 of 7 (permalink) Old 09-28-2010, 01:42 PM
MANIC MECHANIC
vulcanjoe's Avatar
it is ac current coming from the stator. Use this thread to test.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #4 of 7 (permalink) Old 09-28-2010, 01:47 PM
Mushu's Avatar
Send a message via MSN to Mushu
What may be happening is that the stator is actually generating current but not enough to stop the battery from draining. You may want to test the stator leads disconnected from the rectifier, you should be measuring about 35-40 volts AC between any two leads. If voltage is lower then the stator is shorted out somewhere and needs to be replaced.
This test should help you out to determine if the stator is dead.
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #5 of 7 (permalink) Old 09-29-2010, 08:45 PM
IBEW 915 Electrician
hctublerub's Avatar
Had that problem, just fixed it. Battery would be at 12.5v or worse. I'd let the battery charge, take the bike for a ride and after about 15 minutes would have problems. Long story short; after checking all the wire connections and greasing them with dielectric grease I checked the ohm readings on the RR and they were bad. Replaced the RR with a new one and problem solved.
If the battery is not getting a clean DC voltage the battery doesn't charge and the bike electric system runs off the battery instead of the stator/RR system. That's why the battery runs down. All a battery is for is starting the bike.
'01 Vulcan 750
Irridium Plugs
hctublerub is offline
post #6 of 7 (permalink) Old 09-29-2010, 09:51 PM
Send a message via AIM to Mazdaracer4fun Send a message via Yahoo to Mazdaracer4fun
Cool
Originally Posted by nickamudd View Post
Here are the facts:
Thanks,
Nick
SWITCH TESTER TO A/C VOLTS then RETEST! lol stators give out A/C (alternating current) then the REGULATOR/RECTIFIER converts it to D/C Volts and keeps the volts @ 12-14 volts..
also i just had this happen to my bike ... the connector for the regulator had worn out some what, enough that the female ends for the wires inside the connector were loose and causing the one (black/with yellow stripe) wire to lose solid connections and started arcing and over heating the wire and inturn the battery drained cause there was no connection/charging.
just some extra info for ya.
Will H.
Mazdaracer4fun is offline
post #7 of 7 (permalink) Old 10-07-2010, 08:24 AM
Exclamation Stator Cold Check
With the bike off, and using a Resistance / Ohm Meter, measure from each of the 3 Stator Wires to Ground (off the battery (-) or Frame Wire Connection).
You should not read any conduction. Unfortunately I did 3-Ohm.
The Stator put out AC Voltage when Engine was Cool, but declined as it warmed up.
I had one Stator Lead Grounded. The Ground got worse with Heat of the Engine. Replaced Stator, and now Good to Go
Rich
w4nmh is offline
