Headlight failure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-22-2010, 01:52 PM Thread Starter
sam47's Avatar
Headlight failure
symptoms: No headlight - high or low beam. Headlight failure light is not lit. Headlight bulb is new, fuse is good. With engine running voltage at bulb connector is less than 0.1 v. With engine running pulled connector to reserve light device, also no voltage reading greater than 0.1 v. Tried again with connector plugged in, same readings.
Is there any voltmeter test for the reserve light device?
Any ideas on why I am not getting any voltage at the bulb connector?
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #2 of 10 (permalink) Old 09-22-2010, 04:03 PM
Calif Rider
weh44att's Avatar
Most likely your problem is in the fuse junction box. The headlight diode or the relay has gone bad. If you have the downloaded manuel that is going around, you can check page 15-50 for a diagrame of the fuse box. Check the versis for headlight failure and there it will explain how to reposition the blue wire, to get power to the headlight. The trouble is it will come on as soon as you turn the key, this is a temperary fix. You may need a new junction box. The wire is a real PTA to change it's position. Also in the electrical section is how to check out the junction box on page 15-51. Have fun.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 10 (permalink) Old 09-22-2010, 04:36 PM
Here is a link to Gadjet`s Vulcan pages with the "Hunt Shunt" to get your headlights on in an emergency. The JB on the vn1500 is a little different than the 750, but the procedure should work for us too. He describes using a short 2" piece of wire to jump between the blue headlight wire and the empty space in the connector beside it. This empty space always has power when the ignition switch is on, and will power the headlight. This should help you diagnose whether the problem is in the JB or not.
http://www.gadgetjq.com/hunt_shunt.htm
Hope this helps.
post #4 of 10 (permalink) Old 09-22-2010, 10:02 PM
Easy way to fix in move blue wire in the JB to the empty pin on the JB. (I believe it is Pin 8 in the 6 pin connector to the empty pin on the 10 connector)
post #5 of 10 (permalink) Old 09-23-2010, 01:07 AM Thread Starter
sam47's Avatar
Light relay failed voltmeter test
After following the voltmeter test in the VN750 service manual. I got a bad reading on the headlight relay leads. Will order a new junction box. Will post a reply after I get it installed.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #6 of 10 (permalink) Old 10-05-2010, 06:28 PM Thread Starter
sam47's Avatar
put a jumper from jb pin 7 to pin 8
Spent hours understanding the wiring diagram for the headlight and voltmeter troubleshooting the Junction Box and the Reserve Lighting Device. Replaced one at a time both the Junction Box and the Reserve Lighting Device - no luck. gave up all the troubleshooting, could never get 12v coming out of pin 8. Installed a jumper from Junction Box pin 7 to pin 8. Now light comes on with ignition key and stays on during starting. I don't have any starting problems. My mechanic had replaced my Regulator/Rectifier with a higher amp version. Electrical is good on this bike.
Thanks for your suggestions. I would have liked to get it to work like it was designed, but at least now I can get back to riding instead of working on the bike.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #7 of 10 (permalink) Old 10-05-2010, 09:16 PM Thread Starter
sam47's Avatar
Junction Box & Reserve Lighting Device wiring diagram
I have attached a drawing I made from info available from different manual's diagrams. Maybe useful to someone else.
Name:	VN750 Junction Box Wiring.jpg
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #8 of 10 (permalink) Old 10-05-2010, 09:36 PM
Glad to hear that jumping power from one pin to the next got your headlight working.
Can you post a bigger picture of the wiring diagram? I can`t blow it up big enough to read it.
post #9 of 10 (permalink) Old 10-06-2010, 12:04 AM Thread Starter
sam47's Avatar
higher res diagram
This is higher res. if it still isn't good enough, let me know and I will try saving it as a pdf file.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #10 of 10 (permalink) Old 10-06-2010, 10:17 AM
Chavisimo's Avatar
I physically moved my solid blue wire to the empty slot on the connector over a year ago and bike is still running strong without issues. As long as you have a good battery, you should be good to go.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
Tags
headlight
