stator rebuild no start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 09-19-2010, 05:51 PM Thread Starter
tickman's Avatar
Replaced stator today and bike want start. It was running before tare down. I can use starter fluid in carb and starts for a min. trying to trace wires down now any ideas. its weird i pull gas tank off and gas isn't flowing out of peacock with it on, on reserve or off is it supposed to be pressurize to carb
tickman is offline
post #2 of 15 (permalink) Old 09-19-2010, 06:14 PM
flitecontrol's Avatar
Without vacuum from the line running to the carb, gas will not flow. You may need to pull the vacuum line off the carb and suck on it to fill the carbs with gas. Note, you will not get a mouthful of gas doing this.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 15 (permalink) Old 09-19-2010, 08:19 PM
Concert connoisseur
wib714's Avatar
I had to prime mine, would idle but not rev, then I found the one hose I left off and all was good!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 15 (permalink) Old 09-19-2010, 10:15 PM Thread Starter
tickman's Avatar
I believe the peacock is messed up. i can get it to crank now but it wont rev up like it starved for gas. gas should run out with fuel lines off right, but it doesnt . can you take it apart without new seals being bought
tickman is offline
post #5 of 15 (permalink) Old 09-19-2010, 10:22 PM
No, gas will not come out of the petcock unless there is a vacuum applied to the vacuum line. It is a vacuum actuated petcock, NOT a gravity feed.
When the engine is running, the carb constantly places a vacuum on the petcock. The gas left in the carb when you shut it down is what starts the bike the next time you crank it.
"Black Beauty"
Old Blue
post #6 of 15 (permalink) Old 09-20-2010, 12:50 AM
Vacuum line goes to middle nipple on the petcock.
If you have one of the early models (1985 to `87 or`88) with PRI (prime) on the petcock, that position will fill the carbs without vacuum being applied. All other models require vacuum to operate RUN or RES, and have no prime position.
post #7 of 15 (permalink) Old 09-20-2010, 01:27 AM Thread Starter
tickman's Avatar
is there a line going to fuel gauge box underneath gas tank. there's no hose hooked up to it and there is a hose that sticking out near right ear that smells of gas. dont remember either being hook up.
tickman is offline
post #8 of 15 (permalink) Old 09-20-2010, 08:59 AM
No, no hose there. But there is a drain hose that fits onto the nipple protruding from the rear of the tank.
"Black Beauty"
Old Blue
post #9 of 15 (permalink) Old 09-20-2010, 09:02 AM
mine had a hose there ,but why i don't know,it just hung down towards the emissions junk used to live!
post #10 of 15 (permalink) Old 09-20-2010, 09:08 AM
Hmm. I was wondering why there was a nipple on that little box. Guess if mine had one it disappeared before I got the bike. Actually, it's missing from both my bikes!
"Black Beauty"
Old Blue
