need advice on 6pin connector - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 09-19-2010, 12:30 AM Thread Starter
Journey's Avatar
i need to change my name to journey interruptus.
we have managed to trace electrical problem to the vicinity of the 6pin connector. we have over 12 volts coming out of ignition switch on yellow wire. none most of time atJ starter button. moved the wires around and got a connection. QUESTION is there an easy way to access the 6pin connector?
we have managed to fix most of problems and bike sounds like a dream when running.
any and all help appreciated.
email is [email protected]
My Enuf.
1995 Vulcan 750
New wires and plugs
Removed and cleaned carbs
re routed air line to right ear
re built transmission
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #2 of 2 (permalink) Old 09-19-2010, 01:47 AM
if you are talking about the red 6 pin connector for the right control switchs, then you will have to remove the tank, especially if you need to perform repairs.
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
