Regulator schematic - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-16-2010, 09:18 PM Thread Starter
Regulator schematic
DOES ANYONE HAVE A WIRING DIAGRAM OF WHAT WIRE GOES TO WHAT TERMINAL ON THE REGULATOR FOR A 85-02 vn 750? I AM TRYING TO BRING ONE BACK FROM SEVERE ABUSE AND NEGLECT. SOMEONE DECIDED TO CUT THE HARNESS AND HARD WIRE A REGULATOR OFF OF WHO KNOWS WHAT. EVEN IF YOU JUST TAKE A PICTURE OF YOURS, IT WOULD BE APPRECIATED. i AM WAITING FOR A FACTORY MANUAL, BUT WOULD LIKE TO INSTALL NEW CONNECTOR AND REGULATOR SOONER THAN LATER. THANKS!
wignall2 is offline
post #2 of 4 (permalink) Old 09-16-2010, 10:05 PM
Welcome to the Vulcan madness wignall2.
Just a heads up here. Typing in all capitals is considered the equivalent of shouting in the online world, and is poor form.
Regarding the r/r. Look at the connection on the box with the male pins, and the locking slot positioned along the bottom edge.
The top 3 pins are yellow wires from the stator, attached in any order.
The bottom three pins from left to right are labelled G,M and B in the Clymer manual, and the wires from the harness in the same order are white, brown and black/yellow. Hope this helps.
post #3 of 4 (permalink) Old 09-17-2010, 11:42 PM
you can download the manual for free... check my signature. also i have the schematics you are looking for are found in my scribd documents.
post #4 of 4 (permalink) Old 09-19-2010, 03:08 PM
Regulator / Rectifier Wiring Diagram
Attached is the Regulator Rectifier Test Worksheet which has the Diagram.
w4nmh is offline
