Horns - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 09-16-2010, 09:59 AM Thread Starter
MO Rider
eberghold's Avatar
Horns
Anybody put car horns on instead of the 'ee' 'ee' horns? Or electric 'air' horns?
K&N Filters
No airboxes
New! Dunlop 110/90-19 front
150/90-15 rear
Aftermarket pipes
Iridium NGK plugs
"STUPIDITY SHOULD BE PAINFUL"
eberghold is offline
post #2 of 23 (permalink) Old 09-16-2010, 01:32 PM
flitecontrol's Avatar
Lots of folks have put on Stebel Nautilus, Wolo Bad Boy, Fiamms, Hela, and other types in an effort to be better heard. I opted for two Wolo Bad Boy horns. On most of these, you'll need to install a relay as the stock wiring is too puny to provide full power to the horns.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 23 (permalink) Old 09-17-2010, 09:11 AM
baldy's Avatar
I put on a set of car horns from a local parts store $16 each. 1 high and 1 low tone sound great and lets people know you are there. No need to add a relay but will have to do just a bit of tweeking to get them to fit in the factory position. There is a pic in my profile of how they look.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 23 (permalink) Old 09-17-2010, 03:38 PM
I have a set of Fiamm Freeway Blasters (pretty much identical to baldy`s above), fit to my 750, but I do need a relay. The standard wiring will not even give me a peep. Ma Kawi`s beep, beep roadrunner horns are rated at 2.5 amps. The Fiamms are rated at 5 amps. I just picked up a Wolo Bad Boy (identical to Stebel Nautilus compact) airhorn, but cannot find any power rating on it. Someone else said they are 20 amp, but I cant`t verify that. It does need a relay for sure.
All I needed to do, to mount the Fiamms, was remove the rubber mounting grommet for the OEM horns and cut a small metal plug to fill all but the top notch in the bracket where the stud on the new horn goes through. I wanted the horns mounted as high as possible to keep them away from the fender. It was fiddley to get a snug fit, but all I needed was a piece of 1/8 inch strap metal to cut the plug from, a hack saw, a fine flat and ~1/4" diameter round file, and a vise to hold the work piece while I shaped it.
post #5 of 23 (permalink) Old 09-17-2010, 05:12 PM
dirtrack650's Avatar
NO ONE HERE CAN BEAT THESE HORNS!!!
youtube
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 23 (permalink) Old 09-18-2010, 12:50 PM
deefer's Avatar
Send a message via Yahoo to deefer
I have Stebel Dual TM80 Magnum Horns. As loud as the air horns, but more reliable. Will fit where the original Road Runner horns were, but you will need a relay.
Deefer
94 VG1200 Voyager II
deefer is offline
post #7 of 23 (permalink) Old 09-19-2010, 02:02 PM
My duel stock horns seem to be heard quite well for keeping cars from sharing my lane, usually moving in front from Right to Left.
I did manually 'spread' them apart so they angle a little more to the sides instead of just straight ahead.
w4nmh is offline
post #8 of 23 (permalink) Old 09-19-2010, 02:38 PM
MANIC MECHANIC
vulcanjoe's Avatar
youtube
DT
I would have those but they are a bit conspicuous on a motorcycle.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #9 of 23 (permalink) Old 09-28-2010, 06:47 AM Thread Starter
MO Rider
eberghold's Avatar
This relay, off the shelf, have to order? Only one kind?
post #10 of 23 (permalink) Old 09-28-2010, 06:49 AM Thread Starter
MO Rider
eberghold's Avatar
I only have one silver round horn but have extra wires hanging that are the same colors. Need all wires for bigger horn?
