Cutting out on me - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-11-2010, 01:39 PM Thread Starter
Cutting out on me
OK, now I thought this may have been a fuel issue (posted other thread) but I now think it has to be electrical. The engine keeps cutting in and out when I'm riding and the tach is bouncing all over the place when it does. Does this sound like an ignition problem? It is NOT backfiring. Just not sure where to start ripping it apart. When I'm sitting in neutral, the neutral light seems to flicker when I give it gas and it won't hold a steady RPM (bounces all over) As of right now I just took a 2 mile run and barely made it back it. I'm pretty tired from working 3rd shift, so it will have to wait till later this evening or tomorrow. Hopefully I will have some suggestion by then.
Till then, Good night.
post #2 of 7 (permalink) Old 09-11-2010, 02:04 PM
MANIC MECHANIC
vulcanjoe's Avatar
check your voltage while running at the battery and the coil terminals
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 7 (permalink) Old 09-11-2010, 03:13 PM
I had a similar problem with my tach bouncing and it was a bad connection at the battery....
check this thread https://www.vn750.com/forum/showthread.php?t=15287
dariv is offline
post #4 of 7 (permalink) Old 09-11-2010, 07:16 PM Thread Starter
All I have to say is WOW, the negative battery teminal was very loose. Tightened her up and she's running like a top again. I don't know if that's the first place I would have looked, but I'm grateful for the solution. Thanks dariv, I guess that's another thing to put on the list for things to check while doing maintenance. I really thought this problem would be a real head scratcher, but that fix was a simple as it gets, and I only needed one tool to do it, the nutdriver that I have in my tool bag to remove the seat bolts is the same size as the nuts on the battery terminals. Someone was really thinking there!
post #5 of 7 (permalink) Old 09-11-2010, 08:47 PM
cglennon's Avatar
Same thing happened to me; loose negative battery terminal. I found that the battery was not being held down firmly and shifted a inch from side to side. Over time it works the battery terminals loose. I added a shim under the battery hold down bracket and added lock washers to the battery screws to solve the problem.
Chris Glennon - Portland, OR
cglennon is offline
post #6 of 7 (permalink) Old 09-12-2010, 12:13 PM
Just glad to give back a little of the knowledge I have gained here.....
dariv is offline
post #7 of 7 (permalink) Old 09-12-2010, 02:08 PM
gun slinger
centurynick's Avatar
when he said the neutral light was flashing (and my tach would sometimes do weird $hit) that threw up a red flag for me . mine would sometimes be a pita to start . i took the seat off and sure enough the negative cable was very loose on the battery, i could see where it was arching . I tighten her down and the bike cranks over way faster wow this fourm amazes me
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
