keyless ignition - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-09-2010, 11:15 PM Thread Starter
keyless ignition
Anybody have experience with a product like this?
http://www.invisikey.com/
dariv is offline
post #2 of 14 (permalink) Old 09-10-2010, 07:14 AM
VN750_DawgsFan's Avatar
Sounds interesting.
VN750_DawgsFan is offline
post #3 of 14 (permalink) Old 09-10-2010, 12:59 PM
Undercover Sportbiker
AJCruzin's Avatar
I went keyless for my track bike just by rewiring a little bit. Seems spendy, but an interesting concept.
AJCruzin is offline
post #4 of 14 (permalink) Old 09-10-2010, 01:11 PM
baldy's Avatar
I have a friend that has a new HD with this feature. Very cool and easy plus the benefit of a security alarm is a plus.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #5 of 14 (permalink) Old 09-10-2010, 01:23 PM
letitflight's Avatar
i had a similar thing too, but laid the bike a couple times....I forgot to put it neutral
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #6 of 14 (permalink) Old 09-10-2010, 02:43 PM
InvisiBill's Avatar
I like the idea, but I'm not sure I like the way it's set up. It sounds like triggering the motion sensor starts the bike if your keyfob is nearby. I think I'd rather wire it into the starter button, so you still need to push it for the bike to actually start. Otherwise the bike would try to start if you just needed to push it to the other side of the garage or something and had the key in your pocket.
If you wired it into the starter button, then getting close to the bike with the key would be the equivalent of turning the key on. You could just walk up to bike, hop on, and hit the starter button to fire it up. It just seems a little unsafe to have it trying to start with so little input.
It should be fairly easily to replace just the ignition keyswitch with any sort of wirelessly-activated switch. Heck, you could even hook it up with a Bluetooth system paired to your phone and use that as the keyfob. That would have a side effect of keeping you from forgetting your phone too. =)
1985 VN700 A1 (Sold) | 2009 Ninja 500R EX500D9F
VROC #32761
InvisiBill is offline
post #7 of 14 (permalink) Old 09-10-2010, 09:28 PM
Columbus, Ohio
jimkonst's Avatar
You could just use the kill switch for every start and stop. Not perfect, but better than yet another switch.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #8 of 14 (permalink) Old 09-10-2010, 09:43 PM Thread Starter
Bumping the bike turns on the tag reader, to save on battery use. You still have to push the start button to start the bike. Once it is started the system latches on until you either hit the kill switch or put the side stand down. (the latch keeps the bike from stalling if it looses contact with the "key")
dariv is offline
post #9 of 14 (permalink) Old 09-10-2010, 09:48 PM
I might be wrong but from what I understand it doesn't start the bike at all. All it does it put the bike into run mode. You just don't have to put the key in and turn. There are a lot of cars out there now with this installed. First there were transponder keys a key with a chip that told the car it was ok to run since it had the paired chip. If you had a key with out the chip the car would start and die after 3 attempts it would kill the computer of the car. Now it is no key and just a transponder. It tells the car/bike it is on to go into run mode you still have to push a button to have the starter engage. If all you had was a transponder to make the starter jump it would always engage the starter even when running.
rnenrnk is offline
post #10 of 14 (permalink) Old 09-11-2010, 12:47 PM Thread Starter
How about this RFID car alarm/keyless entry modified to ignition rather than door locks?
I'm thinking the relay can be placed in parallel with the existing switch. For under $40 it might be worth a try....
http://www.amazon.com/K9-SOMBRA-KEYL.../dp/B0011EIOJI
dariv is offline
