93' Vulcan 750 low RPM hesitation/miss fire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-09-2010, 10:05 PM Thread Starter
I recently replaced the plugs and battery because my bike wouldnt start at all unless hooked up to a battery tender. Now the bike starts every time, but in the low RPM range, I am getting a lot of miss fire and hesitation. The carbs were just cleaned and rebuilt, but I do not think they were synced. Could the carbs not being synchronized cause this? Or is there some other problem I am over looking? Any help would be appreciated. Thanks
drumminsk8 is offline
post #2 of 14 (permalink) Old 09-09-2010, 10:14 PM
Freedom's Avatar
Dude, you're posting in every catagory! And yes, you should have the carbs synced, especially if you had them rebuilt and cleaned. Also, what else did you do? How's your plugs? And it sounds like your battery is bad or needs to be charged.
Bike is sold, thanks for the help guys. Ride safe.
Freedom is offline
post #3 of 14 (permalink) Old 09-09-2010, 10:19 PM Thread Starter
Im only posting it in multiple categories because Ive been having a problem with getting no help, lol and the plugs and battery are brand new, which stopped the problem of the bike not wanting to start without a battery tender, but i still have miss fire in the lower RPMs, but a sync is what i was thinking
post #4 of 14 (permalink) Old 09-09-2010, 10:57 PM
Ignition timing could be off........ could be running lean.
Also check the plug wires, vacuum hoses, fuel line, etc......
there are a million or so things that can case a miss
dariv is offline
post #5 of 14 (permalink) Old 09-10-2010, 12:00 AM
If you double or triple post your problem in every forum you will just piss everybody off, and nobody will respond. My advice is go back and delete the the threads on the other forums before anyone replies to them. It is frustrating as hell to reply to a thread, then think it was lost when I run across a carbon copy on another forum.
For your benefit and any others new to this forum, you can find all posts since you last logged on by clicking on QUICK LINKS at the top of the page, then click on TODAY`S POSTS. You do not have to search each individual forum for replies to your threads. Don`t ask how long it took me to figure this out. lol
Excuse my shortness in the first paragragh, I don`t often vent like that.
BTW, welcome to the Vulcan madness.
post #6 of 14 (permalink) Old 09-10-2010, 12:03 AM
flitecontrol's Avatar
Please don't do that. Folks here are very helpful, and usually very timely with a response. But multiple posts are annoying, and more apt to result in folks ignoring all the posts.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 14 (permalink) Old 09-10-2010, 12:07 AM
MANIC MECHANIC
vulcanjoe's Avatar
Patience is a virtue young one
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #8 of 14 (permalink) Old 09-10-2010, 12:13 AM
MANIC MECHANIC
vulcanjoe's Avatar
do you smell fuel at idle, have you removed the plugs after running for a bit to examine for flooding. yes it can even happen on newly rebuilt carbs. when i did mine I accidentally had the floats set too high. causing it to flood and stall after running on the highway.
34k so far
coastered
spline lube
TPE stator
post #9 of 14 (permalink) Old 09-10-2010, 12:36 AM Thread Starter
sorry bout the multiple post guys im new to this forum thing and just thought it would help get results, wont happen again
post #10 of 14 (permalink) Old 09-10-2010, 01:09 AM
No problem man, I was a forum and riding newbie a couple of years ago too.
Thanks for deleting the other posts in the engine and carbs forums.
