i got a lil prob... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 09-06-2010, 09:20 PM Thread Starter
i got a lil prob...
my bike will some times start but ya gota wiggle the key a bit but the bigger prob i got, is wen it is running with the clutch held, in its fine, but wen i let it out it dies. no clue. and on top of that my nutral light does not come on and ive looked at the bulb and it was fine. but i belive i was riding it and it was alright.
thank you for you time and i hope i get her runnin sooon.
ryan5191 is offline
post #2 of 11 (permalink) Old 09-06-2010, 09:28 PM
ohio_redneck75's Avatar
kickstand safty switch or netural safty switch
2002 vn750,7800 mile,homemade drag pipes,harley heratige seat,honda sissybar,led rear turn signals,
iridium plugs,marbled,110/90/19 kenda kruz front,
170/80/15 kenda kruz rear,saddlebags.
whats to come****handlebars,highway pegs
ohio_redneck75 is offline
post #3 of 11 (permalink) Old 09-06-2010, 09:34 PM
Ceal's Avatar
On the key wiggling... I had a similar issue... I had to turn the key to the "on" position and it wouldn't start, I had to kinda back it up a tiny bit and then it would start.
I took apart the puck that has the contacts in it. Gave them a nice cleaning and I stretched the springs a tiny bit so they would help make better contact. Works great now.
When you take it apart though, be careful and do it over a table where you won't lose the parts if they come popping out of the puck. It's very easy to do, as long as you don't lose the parts. There's a ball bearing, 3 contacts and 3 springs in there.
Ceal is offline
post #4 of 11 (permalink) Old 09-06-2010, 10:03 PM
The Professor
lance328's Avatar
Make sure the green wire is hooked into the neutral switch @ the back of the motor toward the bottom under the exhaust manifold.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 11 (permalink) Old 09-06-2010, 10:18 PM
Sounds like something in the neutral safety switch circuit. When you let the clutch out, the starter lockout must have a path to ground via the neutral safety switch, or the bike will stop. (with the side stand down) The neutral indicator light must also have a path to ground via the neutral safety switch. There is a green wire that goes to the neu. sw (IIRC, in the back of the trans.) put the bike in neutral and check for continuity from the terminal on the switch and ground. If it's open, then that is your problem. If it's good......follow it all the way back to the JB and test it there. Also, with the clutch out and in neutral, you should have continuity to ground from the Y/G at the JB. ( Y/G to ground represents the circuit from the JB through the clutch sw and neu. sw) Also check the G/W wire at the JB to ground. (side stand sw)
dariv is offline
post #6 of 11 (permalink) Old 09-06-2010, 10:44 PM
lippy's Avatar
try about bit of graphite powder in the barrel as well this works a treat
bike
1986 vn 750
lippy is offline
post #7 of 11 (permalink) Old 09-07-2010, 07:16 PM Thread Starter
wow. thank you all very much for taking ur time and helping me out. i hope to get the prob fixed. im gonna go home now and work on it. thank you all again i appreciate it your input very much. if i have any more problems i definitely kno where to come, here. thank you.
ryan5191 is offline
post #8 of 11 (permalink) Old 09-07-2010, 07:26 PM Thread Starter
oh one other concerin how easy is it to take apart the carb?? it looks weired. it dont have a bowl like im used to.
ryan5191 is offline
post #9 of 11 (permalink) Old 09-07-2010, 10:07 PM
gun slinger
centurynick's Avatar
the first time it was a tad difficult because i have never messed with them now i can do them damn near blinfolded lol there rather simple IMO
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #10 of 11 (permalink) Old 09-17-2010, 07:29 PM Thread Starter
oh cool thanks
ryan5191 is offline
