fan running on a cold engine - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-08-2006, 09:50 AM Thread Starter
I am getting a buddies '86 750 back on the road for him. It has sat in his garage since '93. I have found a few odd ball things here and there. This is a new one.
I hook up the new, fully charged battery, and the fan comes on and stays on...with ignition off. The engine has not run in 13 years, I think that it has cooled down by now.
Ground wire is secured where it is supposed to be, per the manual.
What could be causing the fan to run?
Thanks!
droopydawg is offline
post #2 of 9 (permalink) Old 05-08-2006, 11:21 AM
Uber Member
sounds like a faulty relay that turns the fan on
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 9 (permalink) Old 05-09-2006, 09:59 AM
fergy's Avatar
Or a shorted temperature sending unit. (is there one?)
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 9 (permalink) Old 05-09-2006, 02:55 PM
Ernie's Avatar
Send a message via MSN to Ernie
Pull the black connector off the fan switch on the bottom corner of the radiator. Be careful - it's easy to break off the terminal. If the fan stops then the switch is at fault. If it keeps running then it's almost certainly the relay inside the junction box which is integral with the fusebox. You are not supposed to be able to get the box apart but I managed to pry mine apart once to fix a dry joint on the circuit board. I then glued it back together & sealed it up with some silicone sealant. If it does turn out to be a problem in the juction box it could be worth looking inside to try & see what is wrong. Has the bike been stored outside at any time? If it has then the box could have filled up with water & shorted something out.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #5 of 9 (permalink) Old 05-17-2006, 10:05 AM Thread Starter
What would cause the switch to go bad? Internal malfuction? Rust and phosphate deposits/debris on inside of radiator on the switch? Bike has sat dormant for 13 years. Coolant drained out of a lower hose after dog chewed hole into it.
Think if I take out the switch, clean it up and reinstall, it might work again?
post #6 of 9 (permalink) Old 05-17-2006, 11:21 AM
Ernie's Avatar
Wouldn't have thought debris on the inside of the switch could cause it to go bad but could be worth cleaning it up just to make sure. In my experience they usually fail internally in some way. Pay particular attention to the threads on the switch as that's where it earths to make it work. Did you take the connector off the switch to prove the switch was at fault? The fan should stop when you take off the connector otherwise the problem lies elsewhere. Let me know how you get on.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #7 of 9 (permalink) Old 05-17-2006, 01:18 PM Thread Starter
Yes, disconnected the the wire from the switch and the fan stopped. My instructor even agreed to what you have said.
(Taking a 2yr motorcycle tech course here in Ga and have not gotten to electrical yet.)
Thanks. Will let you know, as a new switch is $77.
post #8 of 9 (permalink) Old 05-17-2006, 03:19 PM
Ernie's Avatar
$77! Sounds about right for any Japanese spares - i'm sure they must think of a number then treble it when they set their prices! I had to buy a new radiator for my VN a couple years ago & it was 350! (around $550). I nearly fainted when the dealer told me the price. Tried calling a few bike breakers to try & get a secondhand one but had no luck. The VN hasn't been sold here in the UK since 1995 so they're getting pretty rare now. Can never see how they justify it when I compare prices for similar car parts. I have an old Volvo 760 station wagon that I use when the weather's bad, had to replace the radiator a while ago & it was 65 (around $107) brand new & it's 4 times the size of the bike one & has an oil cooler in it for the transmission as well.
Anyway, that's enough of my ranting. Hopefully the new switch will sort it & you can start enjoying the bike for the summer.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #9 of 9 (permalink) Old 05-17-2006, 05:32 PM
Uber Member
ehh, the prices are like that because the produce just a lil more then what is needed for the production run of bikes. very little supply+ high demand = high prices. auto parts sometimes are made in the 50% over for spares
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
