Rear cylinder question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-23-2010, 10:20 PM Thread Starter
Bandito
Mellow's Avatar
I just wanted to make sure this is typical.
Take either of the back cylinder spark plug wires off and the bike will still run. Take either of the front cylinder spark plug wires off and the bike shuts off.
1993 Vulcan 750 - SOLD
1996 Suzuki Bandit 600 - Current ride
Mellow is offline
post #2 of 4 (permalink) Old 08-24-2010, 09:19 AM
Crobins365's Avatar
Shouldn't be. Are you sure you're getting spark to your back plugs? If not, then you'd have the symptoms you're describing (no spark at back plugs, so the bike's running only on the front cyl; pull the back plugs and the bike's still running only on the front cyl. Then, if you pull a plug on the front cyl, you're down to just one plug and one intake valve trying to do all the work of keeping the bike running).
C
Crobins365 is offline
post #3 of 4 (permalink) Old 08-24-2010, 09:34 AM
If you only tested at idle, your carbs may just need balancing.
pappa is offline
post #4 of 4 (permalink) Old 08-24-2010, 12:38 PM Thread Starter
Bandito
Mellow's Avatar
I have spark to all plugs, the bike runs fine, no hickups when driving along, I am going to try removing them at 2000 rpm to see if I get the same results to see if pappa is right.
Mellow is offline
