battery dies after 2 days - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-23-2010, 09:06 AM Thread Starter
Duffer's Avatar
Had a bad stator & rectifier. Replaced both. Now the battery reads 13.5 at 2500 rpm and 14.2 at 5000 rpm. However after riding for a couple of days battery is flat. Bike sputters when hot, stalls out and won't turn over.
Old bad rectifier was throwing 19 volts, so I replaced it.
Did I fry the battery (Ysusa MF)? Otherwise, any ideas as to my problem?
The bike is a 2005 with about 30,000 miles.
Duffer
VROC #26950
Canadian Motorcycle Cruisers Chapter 079
York Region, Ontario
Duffer is offline
post #2 of 9 (permalink) Old 08-23-2010, 10:59 AM
baldy's Avatar
It sounds like your charging system is working fine. The battery may have a dead cell and will not hold a charge. Take it to have it tested before getting a new one though. Also check all the connections and ground cables to make sure they are tight.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 9 (permalink) Old 08-23-2010, 11:10 AM Thread Starter
Duffer's Avatar
That's kind of what I thought too.
Duffer
VROC #26950
Duffer is offline
post #4 of 9 (permalink) Old 08-23-2010, 11:14 AM
baldy's Avatar
How old is the battery btw?
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #5 of 9 (permalink) Old 08-23-2010, 04:05 PM Thread Starter
Duffer's Avatar
Battery was new in early May, however I think someone boosted the bike from a car and not sure if the car was running as I wasn't present.
Battery is still under warranty (6 months Yuasa). I am going to have it load tested at Napa and see what it turn out to be.
Duffer
VROC #26950
Duffer is offline
post #6 of 9 (permalink) Old 08-27-2010, 06:53 AM Thread Starter
Duffer's Avatar
WE WERE BOTH RIGHT!
Replaced the battery and everything is perfect now.
Thanks for your assistance and input.
Duffer
VROC #26950
Duffer is offline
post #7 of 9 (permalink) Old 08-27-2010, 08:33 AM
baldy's Avatar
No problem. Have you done a voltage test to see what the volts are at the battery with the bike running? It should be 13.8+/- at idle 1100rpm and 14.8+/- at 4000+/- rpm. If the battery is fully charged don't be alarmed if the voltage drops a bit where the r/r doesn't need to put out as much volts.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #8 of 9 (permalink) Old 08-29-2010, 01:08 PM
Send a message via AIM to Mazdaracer4fun Send a message via Yahoo to Mazdaracer4fun
hey everyone sorry to thread jack but i just did this test and my bike doesnt charge at all. how would i test the regulater/rectifier and the stator???
Mazdaracer4fun is offline
post #9 of 9 (permalink) Old 08-29-2010, 02:38 PM
flitecontrol's Avatar
No need to hijack. The info you seek is in the verses: https://www.vn750.com/forum/showthread.php?t=1146
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
